Author Topic: HP3478A Display problem  (Read 1078 times)
Offline davebutlerTopic starter
« on: November 12, 2022, 03:02:36 am »
Help sought from the brains trust please.
I picked up this HP3478A for a song knowing it had a display problem.
It flashes up part segment & sometimes th full display for a few seconds the nothing for about 30 sec to min then another quick flash.(See pics)
Any help or suggestions would appreciated.
Thanks in advance.
Cheers
Dave B.
Offline PixieDust
Re: HP3478A Display problem
« Reply #1 on: November 13, 2022, 02:01:22 am »
I'm far from an expert but from what I've seen on the HP3478A, the display is impossible to get anywhere from other than another unit with a working display.
Offline TheDefpom
  • YouTuber Nerd - I Fix Stuff
    • The Defpom's Channel
« Reply #2 on: November 14, 2022, 07:13:08 am »
The symptom makes me think it is not the display itself, but more likely to be a power supply or LCD driver problem.
Cheers Scott
Offline Oldtestgear
« Reply #3 on: November 24, 2022, 03:29:13 pm »
The display used in the HP 3488 switch unit does fit the 3478A. The only issue is one of the Ohms indicators (2 or 4 wire) is displayed as a marker rather than the correct symbol. It was possible to buy the 3488s very cheaply a while ago, especially without the modules. Been there, done that & rescued a 3478A from scrap.
FWIW
Phil
« Reply #4 on: November 24, 2022, 04:51:28 pm »
The 3468A uses the same display as well, afaik? You might find a broken one with a good display. A 3478A is a much more worthy destination for the display anyway...
