Author Topic: HP3548 / HP3457 OLED display  (Read 30824 times)
Online Kean
    • Kean Electronics
Re: HP3548 / HP3457 OLED display
« Reply #125 on: November 24, 2024, 08:30:22 am »
I'm happy to dig into the firmware but it won't be for another week or so before I can try assembling any of my PCBs.
In the mean time, from a quick glance you can try to modify oled.c function oled_init() which initializes the display memory with "empty values".
https://github.com/xyphro/HP3457-OLED-display/blob/09a7be32dd252d96eb0008a0b00129694da555cc/software/source/HP3457Oled/oled.c#L141
I would try changing it to something like:
	// fill display memory with non-empty default values
for (uint8_t digit=0; digit<12; digit++)
oled_chars[digit] = 58; // all digits lit
oled_dots [digit] = 0xff; // annuciators / punctuation = all on
You may also need to disconnect the serial input so the display does not update beyond that.
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #126 on: November 24, 2024, 11:58:32 pm »
Turns out, the current draw is low enough on the OLED's, and the specs/size for power inductors is such that I'll have a huge margin for power.
I was looking to optimise the inductors to save space and cost, but the sweet spot is about 1Amp current rating if I want a reasonably low DC resistance, which is way above what the OLED's draw, so this issue is effectively resolved. :)
Last two steps is to design a simple jig to enable the OLED's to be easily aligned while soldering (I'll design it from FR4 so it can be made just like a normal PCB), and to see if the annunciaters can be made to illuminate on self-test (But that's firmware, so might take me a while....)
Offline Miti
« Reply #127 on: November 25, 2024, 02:17:26 am »
 As I said, I took a different approach. Single board and 3D printed back with places for the OLEDs. I've also simplified the schematic, linear regulator supplied from the unregulated 5V (13.5V on 3478A), no opto isolator but 5V tolerant buffers. This is for the 3478A only. All I have left is to select a linear regulator with EN for 8V.
Oh... and Kicad.
Can anyone suggest a jellybean linear regulator with enable for about 200-250mA up to 18V at the input?
Cheers,
Miti
« Last Edit: November 25, 2024, 02:24:38 am by Miti »
Fear does not stop death, it stops life.
Offline wkb
« Reply #128 on: November 25, 2024, 07:53:47 am »
old skool 7805? Cheap as chips. Probably overkill but hé...
Offline Miti
« Reply #129 on: November 25, 2024, 11:02:27 am »
With enable.
Offline eliocor
    • rhodiatoce
« Reply #130 on: November 25, 2024, 01:17:22 pm »
I use those modules: https://www.aliexpress.com/item/1005007369519036.html they are cheap, have an enable pin and works rather well.
For more details:
https://protosupplies.com/product/mp2315-mini-adjustable-dc-dc-step-down-module/
Offline wkb
« Reply #131 on: November 25, 2024, 01:22:22 pm »
I would go for a linear supply. No need add noise from a switcher into a precision measurement instrument!
Offline eliocor
    • rhodiatoce
« Reply #132 on: November 25, 2024, 03:32:40 pm »
Right, he was asking for a LINEAR regulator....
take a look at those lists :
Fixed 8V regulators ordered by price
Adjustable regulators ordered by price
Rohm BDxxFC0 series? Available even on LCSC
« Last Edit: November 25, 2024, 07:41:05 pm by eliocor »
Offline Miti
« Reply #133 on: November 25, 2024, 07:21:38 pm »
Turns out, the current draw is low enough on the OLED's …
What is it?
Offline Miti
« Reply #134 on: November 25, 2024, 07:22:29 pm »
Thanks, I think I found what I’m looking for.
Offline eliocor
    • rhodiatoce
« Reply #135 on: November 25, 2024, 07:42:34 pm »
see my previous suggestions (message modified AFTER your last post)
Offline Miti
« Reply #136 on: November 25, 2024, 09:44:32 pm »
Thanks but I think an SOT23-5 would do it. Xyphro measured only 20mA supply current so by my calculation 13.5-8=5.5V x 50 mA = 275mW. So if it takes 50mA the regulator dissipates 275mW which should be low enough. I’m waiting for TERRA to confirm the supply current. Moreover, I found SOT23-5 with the same pin out from Digikey and from LCSC, under 50 cents each.
« Last Edit: November 25, 2024, 09:48:02 pm by Miti »
  • Country: jp
« Reply #137 on: November 25, 2024, 10:30:29 pm »
What is it?
Under normal operation (idle in DC range after booting the meter) it draws about 24mA on the 8V rail.
I'm using approximately 1A rated inductors with a 4x4mm footprint (they were the best cost/availability/specification ratio) so I didn't do any further testing.
I'd say work on figuring at least double at about 50mA to be safe.
« Last Edit: November 25, 2024, 10:32:10 pm by TERRA Operative »
Offline Miti
« Reply #138 on: November 26, 2024, 11:29:14 am »
The way to calculate this is: PDmax = (Tjmax - Ta)/ ResJA for the ambient and ResJC for the copper.
For the AP2205 in SOT25 package for example that is: PDmax = (125 - 35)/160 = 560mW
For 13.5V in and 8V out that is 560/5.5 = 101.8 mA.
Any objection to this schematic?
« Last Edit: November 26, 2024, 12:04:47 pm by Miti »
Offline Miti
« Reply #139 on: December 08, 2024, 11:51:29 pm »
Ok, les jeux sont faits, rien ne va plus, the boards are with JLC. I've also designed the plastic bracket, 3D printed it and looks ok. This is just the board side, once I get the OLED modules I will draw the OLED side with recess for each module for alignment. Unfortunately LCSC has exactly zero stock of 0.87" OLEDs  :(.
« Last Edit: December 08, 2024, 11:53:26 pm by Miti »
