I put my active probes with 10 Vpp sinusoidal signal with sweep rate of 500 ms from 1 MHz to 100 MHz with siglent sdg 2042X, you can observe linearity on channel 1 from Tektronix probe and you can see how micsig can't give 100 MHz specified in its datasheet. I did that because my Fluke 199c is 200 MHz oscilloscope starts to attenuating from since 60 MHz, I wanted to know how good the response of the probes was as a function of frequency, it is clear that it is not a bode plot, but it gives me an idea of how reliable it could be to take measurements with the micsig probe in that frequency range.
Regards
