Author Topic: HP54600A SOFTWARE REQUIRED  (Read 279 times)
Offline petermovTopic starter
« on: November 09, 2024, 04:09:38 pm »
Hi all!
I´ve recentlly found on a wasted warehouse a functional old hp54600, frame and some controls lost but I finally using lidar scanner and a 3d printer achived fix it. I want to use to trace some spi and i2c signals, I want to use with and old parallel port-cable and some hp datalogger or matlab if it is possible.
Somebudy have drivers or any valid suite? (dont mind to use W95 or W98)
Thank you so much in advance!!!!!! ^-^
Re: HP54600A SOFTWARE REQUIRED
« Reply #1 on: December 24, 2024, 05:40:10 pm »
Yep yep... finally I converted thanks old documentation a kind of parallel output into rs232 and and agilent app datalogger from scope to computer. My project now turns on using Labview with this device.
