Author Topic: HP8644A PLL and FLL errors  (Read 3238 times)
Offline tkamiyaTopic starter
« on: January 19, 2018, 04:17:40 am »
I have an HP 8644A that displays the following error intermittently.
Trans VCO FLL OOL
NF PLL OOL
They usually happen when I make frequency excursions relatively fast.  Mssg indicator comes on and those are what gets displayed.  Other than this though, the unit itself appears to be functioning.  Oddly enough, I went through every manual I can find online and there are no mention of these errors.
Has anyone seen these?
Re: HP8644A PLL and FLL errors
« Reply #1 on: January 19, 2018, 04:58:33 am »
By the way, I just did the self-test and it concluded with result = 0.  It passes self-cal also.
Offline Tony_G
  • Checkout my old test gear channel (link in sig)
    • TGSoapbox
« Reply #2 on: January 19, 2018, 04:48:10 pm »
I can only find one reference to this one the HP Yahoo Group - In that case the A8 board was missing.
Maybe it is related to the power rails sagging? Trying hooking a scope up to the rails and seeing if you can reproduce the error.
TonyG
« Reply #3 on: January 20, 2018, 03:00:33 pm »
That's just it....  not much info on the Internet.
I'll check the power supply just in case.  Unfortunately, reliable reproduction is not possible.  It happens after a while, immediately, at all frequencies, and after lunch and dinner.  I hate intermittent issues.
