Author Topic: Build a Clone of the Tek P6602 Temperature Probe  (Read 3471 times)
Offline med6753Topic starter
« on: May 11, 2016, 04:37:32 am »
One of the features of the Tek 2465 DMS with the DMM option is the ability to measure temperature using the Tek P6602 Temperature probe. The probe utilizes a thermistor as it's measuring device. A quick search of the web for either the probe itself or a manual has resulted in what I think are ridiculously high prices for either the manual starting at $20 or the probe itself starting at $50. If it's just a thermistor why not build a clone? But the only info I can find on the thermistor is that it should be 100 ohms at 0 degrees C. And it doesn't specify if it's NTC or PTC. But thermistors are sold specifying their resistance at 25 degrees C. So....does someone have a manual or the probe and can tell me the thermistor value at 25 degrees C? That would also tell me if it's NTC or PTC. That would give a starting point to experiment.
Thanks.
Online Vgkid
Re: Build a Clone of the Tek P6602 Temperature Probe
« Reply #1 on: May 11, 2016, 07:04:14 am »
100 ohms at 0.0c is a pt100 rtd.
« Reply #2 on: May 11, 2016, 10:55:25 am »
Offline PA0PBZ
« Reply #3 on: May 11, 2016, 11:38:59 am »
If you want to experiment why not hook up a 200 Ohm pot? Turn it so that the 2465 shows 25oC and measure the value.
« Reply #4 on: May 11, 2016, 10:25:50 pm »
That's an excellent idea.  :-+ I'll give it a try.
Offline edavid
« Reply #5 on: May 11, 2016, 11:35:53 pm »
Yes, that's what it is... *not* a thermistor.
BTW, good luck finding a mating Lemo connector for less than the cost of a complete probe.
« Last Edit: May 12, 2016, 01:17:33 am by edavid »
« Reply #6 on: May 12, 2016, 12:31:38 am »
Why would I need a Lemo connector? The probe plugs into the DMM input which are standard banana jacks. It does not plug into the powered probe jacks on the scope mainframe.
Offline edavid
« Reply #7 on: May 12, 2016, 01:18:23 am »
Oops, it's the P6601 that has the Lemo.
