Author Topic: HP/Agilent 1675x logic analyzer card memory up-hack  (Read 5132 times)
Offline MarkL
« on: September 22, 2017, 02:18:42 am »
In the course of repairing some 1675x cards, I discovered that HP/Agilent is using resistors to set the model ID, and hence the capture memory size on these old logic analyzer cards.  The main clues were:
- All models already have the full complement of memory for their series,
- There was sloppy soldering work (solder splatter, flux residue) on unpopulated resistor pads that were in an obvious grouping (indicating that some had been removed after manufacture),
- The only indication of the model number was a solitary adhesive sticker,
- And finally, HP/Agilent is known to use ID resistors in other products.
I haven't seen this info anywhere else, so I'm posting here.
I've verified the following ID conversions work (with full memory testing):
  16751A --> 16752A
  16754A --> 16756A
  16755A --> 16756A
Specs and other details for the cards discussed in this post:
  http://literature.cdn.keysight.com/litweb/pdf/5968-9661E.pdf
Series: 16750A, 16751A, 16752A
Memory: 34 x Micron 48LC4M16A2-8E
Max model: 16752A with 32MSa
There are nine ID resistor footprints arranged in a column: R735, R65, R66, R68(?), R63, R73, unlabeled, R78, and R82.  They are near the pair of Altera LQFP's near the backplane connector.  (It's possible R735 does something else besides ID, but it's unpopulated and near the others so I'm including it.)  To make a 16752A, all the resistors are populated except R735, R66, R63, and R82.  Resistors are 1k 0805.
There are also "B" versions of each of these cards.  The (bad) photos I can find look like they have the same layout, so I would expect it to work with them also with possibly different resistor labels or combinations (maybe one controls the A vs. B?).
Series: 16753A, 16754A, 16755A, 16756A
Memory: 18 x Micron 46V16M16-75
Max model: 16756A with 64Msa
There are eight ID resistor footprints arranged in a matrix: two rows A and B, and four columns 1, 2, 3, and 4.  They are near the Xilinx FPGA U128, which is near the backplane connector.   To make a 16756A, all resistors are populated except B3 and B4.  Resistors are 1k 0805.
There's also an EEPROM on this card, but it doesn't seem to have anything to do with ID.  It's probably only used for calibration data.
Other Cards (which I don't have so I can't try it)
The 16740A, 16741A, and 16742A from photos look very similar (perhaps identical?) to the 16750A/51A/52A series and with ID resistors in the same PCB area.  Hopefully a 1674x owner can figure this one out since it might need different resistor positions populated.  Please post your results if you try it.
I'll also note that the 1674x and 1675x series cards are identical spec-wise except for memory configurations, occurrence counters, and maximum state speed.  So, I suppose it's possible that a 1674x could be turned into a 1675x by using only ID resistors, but it would require a closer look at the memory configuration on the board and subsequent testing at higher speeds.  Again, something for a 1674x owner to try.
It may also be possible to turn a 16718A (8Msa) into a 16719A (32MSa), but I can't find enough photos to know if the board layouts and memory configuration are the same.  The 16719A at least has a similar board layout to the 16740A/41A/42A and 16750A/51A/52A series, so it probably has ID resistors.
Somewhat related to this topic, I've also heard of a hack to turn a 16533A 250MHz 1Gsa/sec scope card into a 16534A 500MHz 2Gsa/sec scope card via a resistor ID.  If anyone knows the specifics, please feel free to share.  Or if you have a 16533A, post a high-res photo (front and back) and I can probably figure it out from there.
Good luck if you try any of this, and please post your results here if you do!
« Last Edit: September 22, 2017, 02:20:16 am by MarkL »
The following users thanked this post: Drewbie, Patrick.M
Offline gslick
Re: HP/Agilent 1675x logic analyzer card memory up-hack
« Reply #1 on: September 22, 2017, 02:50:18 am »
Interesting information. This is the first time I have seen this. Thanks for sharing.
I'll have to check what types of modules I have. I think have all three of 16750, 16751, and 16752, and at least either a 16718 or 16719, or maybe both. Is the 16717 populated with a different memory configuration? Maybe only a 16741 from that line.
I've never bothered doing a careful examination of differences between the modules myself.
(I also have some of the 16753 - 16756 line that I have never used as I don't have any use for the 90-pin POD connectors).
« Last Edit: September 22, 2017, 02:55:05 am by gslick »
The following users thanked this post: Patrick.M
Offline MarkL
« Reply #2 on: September 22, 2017, 02:05:07 pm »
No problem; hope it's of some use.
I have a 16717 and it's significantly different than the others.  It has 34 x OKI M5416283 (256k x 16).  That comes out to 2Msa (34 * 256k*16 / 68channels), which is the 16717 spec, so there's no additional memory to be enabled.  Same with the 16715.
I'm also noticing there's the 16710A (8k), 16711A (32k), and 16712A (128k) which I missed on the datasheet before.  They also have the same specs except memory, so they may be a candidate too.
There may also be opportunities for cards in the 16500 series, but I have zero experience with them.  I think 16900 series card options are software controlled.
The 90-pin flying lead probe kits are outrageously expensive, which kind-of kills the attractiveness of those cards compared to the others.  I'm looking at building some single-ended probe breakouts (some day) out of E5378A adapters.  They're pretty cheap on ebay (~ $20), but I'll never get the kind of fidelity needed for the speeds of those cards.
Offline MarkL
« Reply #3 on: September 22, 2017, 02:39:32 pm »
I don't think it would have occurred to me either.  What tipped me off was reading the service manual for the 16755A I was repairing at the time.  The manual covers all four 16753A/54A/55A/56A cards and talked about the use of 256Mbit DDR SRAMs for the acquisition memory.  My lesser card would presumably not need all the memory installed, yet, it didn't have any unpopulated memory footprints.  Hmmm...  Why is that?
Offline texaspyro
« Reply #4 on: September 23, 2017, 01:14:53 am »
You can also upgrade a 16533A scope board to a 16534A board with a resistor mod.  Sorry, I can't find my notes on which resistors to change and no longer have a 16533A to compare to a 16534A. I seem to remember all the needed resistors were on the back.
« Last Edit: September 23, 2017, 01:17:40 am by texaspyro »
Offline alm
« Reply #5 on: September 23, 2017, 01:35:45 pm »
I remember adding up the memory installed on a 16750A once and figuring out is was much more than the specified memory depth. Good job on figuring out the resistor combinations, I could never find sufficiently high resolution pictures of the 16751/16752A cards to figure out the correct resistor combinations.
The 1675xA and 1675xB are the only cases I know where cards with different models are supported in a mixed master/slave configuration (so 16750A and 16750B may be connected through ribbon cables as master/slave, unlike say a 16741A and 16750A. So I expect the 1675xA and 1675xB series to be very similar. Not sure what the exact difference is that triggered changing the model. A slight change in specifications?
What's the point of using the 16753+/16760 series if you are not using differential inputs or high speed? The factor two increase in memory depth compared to the 16752A is barely worth the hassle. The various adapters to single-ended Mictor or single-ended or differential Samtec are probably the only affordable solution with decent signal integrity. Many later HP logic analyzer boards have Mictor footprints on them, and you can obviously design in whatever connector you want on your own boards. The 90-pin flying lead pods are more complicated than the older 40-pin pods to improve signal integrity (not surprising, given that the 40-pin pods were designed in the late eighties).
Offline MarkL
« Reply #6 on: September 23, 2017, 04:35:48 pm »
Not much, I agree.  My mainframe came with a pair of 16751A, and a 16754A.  I never really used the 16754A for anything.  I later came across a broken 16755A for dirt cheap which I was able to fix mostly for the fun and challenge of it.
One additional nice feature in the higher speed cards is the eye scan across all inputs, but again not something I've needed or currently have the appropriate probing for.
No idea on the A vs. B versions.  They look the same from all the photos I've seen, and a diff on the A and B service manuals reveals nothing.
Offline fisafisa
« Reply #7 on: September 25, 2017, 11:34:38 pm »
aaagh!
as I suspected the 16533 can become 16534.... :o
anybody with high res pics of the back of a 16534?
thanks
Offline texaspyro
« Reply #8 on: September 26, 2017, 01:27:52 am »
aaagh!
thanks
I think these are the guys:
On 16534A: top side, near the Actel chip:  R810=0  R809=1004
On 16533A:  R810=1004 R809=0
I remember swapping two resistors...  on the 16533A they were hand soldered at the factory.
Also, there are at least two versions of the 16534 (A and A2)... one has a two PGA chips, the other has a single PGA chip and a chip that does not have pins... The different chip is labeled U508 and U509.
« Last Edit: September 26, 2017, 01:31:12 am by texaspyro »
The following users thanked this post: alm
Offline MarkL
« Reply #9 on: September 26, 2017, 03:14:46 pm »
aaagh!
thanks
Good memory!  That seems to be the recipe!
I took one of my 16534A cards and swapped R809 and R810.  It became a 16533A.
Using a 0dB reference point at 10Mhz, the 16534A had a -3dB point at 623MHz (not bad - I hadn't measured this before).  When it became a 16533A the -3dB point was reduced to 346MHz.  So, even back then it seems HP was doing their artificial limits on BW.
Someone with a card manufactured as a real 16533A should double check this to make sure there's no other changes needed.
There's at least three versions that I've seen.  U501 and U509 vary.  U508, the trigger comparator, is either there or not.  The comparator function and some driver circuitry for it around the U200 DAC appears to have been absorbed into U509 in some card versions.
Offline texaspyro
« Reply #10 on: September 26, 2017, 05:40:54 pm »
I originally found those resistors when, many years ago,  I bought a couple of expansion chassis that had 4 x 16533A's in them.  Last night I dug out a defective 16534A that I tried to back-grade to a 16533A to see if that made a difference (didn't) and spotted the swapped resistors.   I originally thought the resistors were by one of the PGA chips...  That was probably a different board I was remembering.
Offline fisafisa
« Reply #11 on: September 27, 2017, 10:52:49 am »
Thanks.
I will try the modification.
Offline DocBen
« Reply #12 on: November 18, 2017, 08:15:06 pm »
Hi there,
I can confirm that a 16740a can be converted to a 16742a by removing one resistor. I used a picture of a 16742a.
I also tried to convert it to a 16752b but that failed, probably because I only have 1.5k resistors and I think the resistors create a voltage divider so I probably had the wrong voltages.
I will try again once I have some 1k resistors.
Offline DocBen
« Reply #13 on: November 28, 2017, 05:49:08 pm »
Yatta!
So I have finally gotten around to try to get a 16740a to be a 16752b.
On my third attempt I succeed. (keep in mind however this just passes the self tests. I havent made any actual measurements with it so it might fail when doing actual work)
from R735 to R82:  - -RR-RRR-
does it. (- open, R well, you know)
I used 1K 0.1% Resistors just like they are used on the board
The following users thanked this post: alm, Patrick.M
Offline MarkL
« Reply #14 on: November 28, 2017, 06:55:49 pm »
Wow, that's interesting!  Of the many possibilities for ID upping, I would have ranked the 16740A --> 16752B as having one of the least chances of actually working.
Does your 16740A have the same amount of memory populated as a 16752B?  The 16752A has 34 x Micron 48LC4M16A2-8E (4M x 16).
Offline gslick
« Reply #15 on: November 28, 2017, 10:23:38 pm »
I just took a look at the 16741A that I have. It has (34x) MT48LC4M16A2-75 64Mb (1 Meg x 16 x 4 banks) parts. So if my math is right that should be sufficient for 32M samples of 68 channels, even though the 16740A, 16741A, and 16742A are 1M, 4M, and 16M analyzers.
Offline MarkL
« Reply #16 on: November 28, 2017, 11:53:18 pm »
Your math is right: 34chips * 4M*16/chip = 2176M/68ch = 32M/ch
Plus you have the -75 version which is a 133MHz part and I have the -8E part in a 16751A which is 125MHz, so it would be reasonable to assume the upped 1674x cards can also do the full sample rate of 400Msa/s.  Some verification testing from DocBen (or yourself, if you feel like playing with it), would tell for sure.
That must have been some pretty fine segmentation in the market to make Agilent produce 6 different performance levels on essentially the same hardware.  Go sales team!
Offline gslick
« Reply #17 on: November 29, 2017, 12:53:27 am »
There is flux residue around the pads of two of the unpopulated resistors on my 16741A module. I wonder if those resistors were populated during manufactured and initial testing in a maximum configuration and then removed when the module was configured to be a 16741A.
Does someone have a photo of a 16742A for comparison?
Offline DocBen
« Reply #18 on: November 29, 2017, 09:44:34 am »
Well it makes a lot of sense to have the exact same hardware, because it effectivly eliminates testing and designing of different products and eliminates the need for early product differentiation.
So you can buy in bulk.
I didnt try to solder in all resistors, but it will probably not be recognized by the analyzer (factory test setting?)
Also if you think about: the memory is run of the mill Pc100/PC133 memory not even special temperature range or rad hardend. Even if they built 10000 cards thats not even 500k chips for the whole lifetime of the cards. A PC manufacturer back in the day probably used that per day or per week. Micron probably asked when they would stop sampling and start buying  ;)
I guess thats also the reason why all the other chips come in multiples: it is just cheaper (or you cant even get them in lower quantities).
@gslick: I think that card was originally a different model. might have been a 16750b not sure.
forgot to take a picture of my card when I modded it to be a 16742a but I think R68 belongs at R63 not sure. ebay constantly wants to give me a free iphone so I cant look at the pictures of 16742a there right now, but you can give it try
« Last Edit: November 29, 2017, 09:48:55 am by DocBen »
Offline DocBen
« Reply #19 on: November 29, 2017, 04:33:38 pm »
I just checked what kind of equipment you need to actually verify specs (from the service guide):
- a pulse generator with 200 MHz (still reasonable) with 2.5 ns pulse width and < 600 ps rise time (and i'm out)
- a digitizing oszilloscope (check) with >= 6 GHz bandwidth, < 58 ps rise time (and i'm out)
so at least an "offical" verification is off the table for me.
I might do some experiments with an FPGA ( upduino when (if) I get it ) as it supposedly has a 275 MHz PLL onboard that can drive an I/O pin. Maybe clock doubling with an XOR gate from potato semi and a clock buffer. That setup could in theory reach 800 MHz but I don't have an oscilloscope that can verify that so  :-\
Offline DocBen
« Reply #20 on: December 01, 2017, 08:04:51 pm »
the 16960As have a similar feature it seems. There is a field of resistor rows above the main ASIC.
And it is suspiciously different for 4M and 16M cards ;)
Now I only have to unbrick the three I have. Maybe I'll get to that this weekend, maybe next.
Does anybody have the (native) 100M version of the card?
I think there is different resistor value on there. Mine are all blu, dont know the value yet, but on pictures the first resistor of the second row looks different on the 100M card. But maybe thats just the pictures I saw on ebay.
Offline CatCow
« Reply #21 on: December 31, 2017, 06:45:58 pm »
Glad I saw this thread today... I was working on my 16903A/16910A this morning, after finally obtaining some parts as an experimental repair. Got a good deal on it from eBay, has two 16910A cards - 250MHz state, 256k memory on one and 4M memory on the other. The 4M card had a large number of memory errors. It may not be the memory, but I decided to try replacing those chips - my first attempt at SMT rework. Well there are also clock errors, and now after the "repair" another memory chip is throwing errors.
I noticed that there is a similar pad of jumpers for the board ID to the older models... Two rows of six small blue SMT jumpers. I didn't remove one to measure, got about 4.2k ohms across an installed one. As seen in the attached photo, the 4M 250MHz card has all jumpers in place except B6. I didn't take a photo of the 256k, but it had all jumpers except B5. Given the failed attempt at repair and other more difficult to diagnose/repair problems on the board, I will probably attempt to play with the jumper locations and see what happens. If it works out well, maybe it will be worth trying to hunt down the clock error...
Offline gslick
« Reply #22 on: January 01, 2018, 05:49:39 am »
One thing that is different about the 16910A module is that it can be upgraded in the field by the customer by installing a software license. Possibly the licensed sample depth / state speed configuration is stored in the serial eeprom along with the serial number.
If you were adventurous and have multiple 16910A modules to experiment with maybe you could try removing and reading the serial eeproms to compare the contents between multiple modules. Maybe there would be obvious differences for the module serial numbers, any maybe some not quite as obvious differences for licensed sample depth / state speed configuration option differences.
Offline CatCow
« Reply #23 on: January 07, 2018, 08:38:17 pm »
Well the 16910A looks to be more controlled by software than hardware as you suspected. I did manage to break it enough to say that it was an invalid board(and an FPGA error message that wasn't showing up otherwise), but anything that worked was not recognized as a different spec module. I may spend some time tracing the clock signals and see if there is anything to be done there for trying to make the board operational, otherwise I see a lot of clock fanout chips that may find their way into a GPSDO project(would be just my luck if that was the bad part). Bridging all the pads has brought it back to a point where it will be recognized, but unless I find a cheap board on eBay to go in it, I'll probably just use the single working board. Not exactly limiting for what I might use it for.
Offline perdrix
« Reply #24 on: February 13, 2018, 04:32:17 pm »
Did anyone who has both 16717A and 16719A boards ever find the time to compare to see it the 16717A can be upgraded too (I'm up for upgrading the ROM ICs if I can find suitable ones).
If necessary I can pull a 16717A from the analyzer and take pix.
Or are the 16718A/19A different beasties altogether?
Thanks
Dave
Offline csc316
« Reply #25 on: March 28, 2018, 11:23:51 am »
I can confirm that converting a 16533a 1GSa oscilloscope board to a 16534a 2GSa board is as simple as swapping resistors R809 and R810.  Just did it.
The following users thanked this post: MarkL, alm
Offline Patrick.M
« Reply #26 on: April 01, 2018, 09:57:28 pm »
I just became a member as of now.
Here is a shot of the resistor option configuration on my 16742A.
As far as I can see, the 1675X and 1674X PCB are the same, see images.
I would suspect that hp (Agilent) loads what software is need for a 75X over a 74X by it's ID Type.
Offline Patrick.M
« Reply #27 on: April 01, 2018, 09:59:28 pm »
So far as I can see, from my 16750A and 16742A, they are simply the same PCB.
Offline Patrick.M
« Reply #28 on: April 02, 2018, 03:48:38 am »
I use the 16720A PG as a pulse generator to test my LA boards. Does a really good job.
Offline MarkL
« Reply #29 on: April 02, 2018, 06:45:18 pm »
Thanks for the photos, Patrick.
Are you going to up-hack your 16742A to be a 16752A?  DocBen, a few posts back, was successful in getting a 16740A to be a 16752B, but was unable to do detailed testing to make sure everything worked at 1675x speeds.  Perhaps you can do some testing if you decide to modify your 16742A?
Offline MarkL
« Reply #30 on: April 02, 2018, 07:06:39 pm »
Thanks
Dave
I have a 16717A and it's nothing like the 16719A, looking at pictures on ebay.  Also, a count of the populated memory on the 16717A says there's no unused memory laying around waiting to be activated.
I've never heard of any options for upgrading memory chips on these cards.  The memory is a 64-pin package and there's 34 of them.  Seems like a lot of work even if it was possible.
The 16719A looks a lot like the 1674x and 1675x series, but there's not sufficient resolution in the photos to figure out what memory is populated on it.  One photo that's on ebay right now has a sticker indicating it's a 16719A.  I wonder what's under the sticker...
Offline Patrick.M
« Reply #31 on: April 02, 2018, 09:37:38 pm »
Mark,
Not any time soon. I'm all good on the idea of unlocking sequestered memory, but not so sure that changing from a slower class to a faster class of a digital product actually works as well as expanding the memory. My pessimistic thinking here says one could be yield issues, say with the gate array, ADC driver with some fixed calibration for that unit that relegated it to a slower product class. Just thinking.
With this, does anyone know if changing a16533A (250 MHz. 1Gs) scope to the 16534A (500 MHz. 2Gs.) with test results? I'm reluctant to do anything with mine. Even though I can see no differences between the two PCBs what so ever.
Offline texaspyro
« Reply #32 on: April 02, 2018, 09:45:14 pm »
I don't have any formal test results, but I have been using some upgraded 16533A's for years without any issues.    I just swapped the resistors and ran the calibration routine.
Offline Patrick.M
« Reply #33 on: April 02, 2018, 10:34:02 pm »
I'm fast becoming convenced it's the real-deal. I just wen't over my 1533A and 1534A and discoved that both have the same type markings on the chips. Two actually say 1534A on both boards. The front end attentuator module even has the same 1534A markings. I guess engineers are clever at geting components to do what we wan't them to do, so why shouldn't marketing engineers allow a feild engineer to perform an upgrade to lower end products, conveniently in the field, impressing certain customers who ghen may become very loyal.
I'm doing the R swap today and will let youall know.
Offline texaspyro
« Reply #34 on: April 03, 2018, 12:50:00 am »
I once bought a couple of expansion chassis that had 16533A's in them.   I noticed that those two resistors were hand soldered (flux residue) and the 16533A's had stickers for the model number applied over the 16534A on the board.   That clued me in that it was upgradable.   I checked a 16534 and found the resistor swap.   I suspect that HP builds 16534's and downgrade them when somebody buys the low end version.
Offline Patrick.M
« Reply #35 on: April 03, 2018, 01:49:08 am »
I just finished a series of step response tests on the two scopes in the same chassis. One my stock (stickered) 16534A, the other my stock (stickered) 16533A with the resistor swap. I'm a believer and satisfied as both can do better than 1.5 ns. rise and fall times.
What was that LA board I should speed up?
Offline texaspyro
« Reply #36 on: April 03, 2018, 03:34:37 am »
Whoopie!   :-+
Offline Patrick.M
« Reply #37 on: April 03, 2018, 04:44:03 am »
There are a modest number of legacy products hp, Agilent produced that are truly timeless, still useful today (and more so) and has a high degree of sovereigncy. The 1670X series is indeed a member of this elete club. I say sovereign, because it can operate entirely on it's own grounds, quite compatable with the newest PC's that can run a decent Xterm program. I use mine somewhat professionally and academically.
I can have big screen monitors on modern PCs with many of the tools on them from the 16700B running MobaXterm. Additionally, you can communicate directly with it via a number of methods under software control. I'm still learning all of it's untility. In my view, this helps make it very useful even though it takes time to boot and is big. I don't think the new replacement can do this and is still big and still takes time to bootup.
Offline Patrick.M
« Reply #38 on: April 03, 2018, 03:43:31 pm »
Now I'm wondering if the 54622A & D scopes have any resitor options. I have yet to look the PCBs over real good, but as I remeber, it was real easy to mix up the 60MHz. 54621A with the 100 MHz. 54622A PCB as they both fit into exacly the same chassis.
Offline Patrick.M
« Reply #39 on: April 03, 2018, 06:31:54 pm »
Unless I'm confused (easy to get so), your resitor line-up is different than what is shown in the original image that  MarkL posted. I decided to move the resistors on my 16742A to that of a 16752A. The main frame reported an error trying to write to the FPGA. Fortunatly, restoring the resistors to the 16742A configuration reversed the problem where all tests out okay. Could you look into this, please? If anything to get my mind straight.
I still work and am not able to spent much time with this, but seem to be getting the idea that retirment may be okay after all.
Offline MarkL
« Reply #40 on: April 03, 2018, 08:15:51 pm »
Maybe there's some dependency on the exact model number after the dash.
The number under the sticker on both my 16751A (now turned into 16752A cards), is 16750-65501, same as your 16742A.
Did you try the resistor combination that I posted in the beginning of this thread?
Offline Patrick.M
« Reply #41 on: April 04, 2018, 04:05:12 pm »
MarkL,
Yes, with 1K resitors. This is the only, 16742A I have, so I'm being a bit carfull with it and was rather happy to see it operate again. I seem to have an overt fondness & respect for this legancy equipment that sticks in my mind,  as I remeber all to well how unique and expensive it was in my earler years. Now my shop is awash in it, but only with what I use or really like to play with.
The main frame is a 16702B (SN: MY42001077) with option 003, OS, Software: A.02.90.00
16742A (SN: MY42000173)
The upgrade on the scope from a 16553A to a 165534A wen't quite well as did my 16750A to 16752A.
Offline MarkL
« Reply #42 on: April 04, 2018, 05:14:48 pm »
Interesting that didn't work.  Maybe there's some differences or changes elsewhere on your board that makes it a 16742A.
One thing we've all noticed is that Agilent was quite sloppy in removing ID resistors to create the target board model.  Do you see flux residue or sloppy soldering anywhere else on your 16742A besides the resistors already pointed out?
Would you mind posting some high res photos front and back?  Or since you have both models there, you could also compare the two up close.
You have the same 16702B I have with the same software, so I don't think that's a factor.  There should be no harm in moving the resistors around, other than the mechanical stress from soldering.  But I understand your concern.
Offline Patrick.M
« Reply #43 on: April 04, 2018, 06:34:06 pm »
Nope, boards were clean. I actually did post images of the two boards about three days ago. I'm still trying to figure out how to use this blog, so you may need to scan for them as I seem to have to rescan where I was when I make a reply (post) every time I gat back on.
Offline Patrick.M
« Reply #44 on: April 05, 2018, 03:49:13 pm »
Mark,
So, I'm assuming you were sucsessful at moving your 16742A to a 16752A, yes?
Sorry as It's a bit clumsy for me researching the blog for just posts from you. Perhaps it's because I'm using an iPad.
Offline MarkL
« Reply #45 on: April 05, 2018, 04:10:31 pm »
Mark,
No, I had two 16751A and turned them into 16752A.  DocBen reported he was able to make a 16740A into a 16752B here:
  https://www.eevblog.com/forum/testgear/hpagilent-1675x-logic-analyzer-card-memory-up-hack/msg1361396/#msg1361396
I was only saying that since you and I both have 16750-65501 etched on the cards, I was expecting it to be the same base model but with different ID resistors.  Since the 16752A ID combination didn't work for your 16742A, there must be something else that's making the cards different.  I haven't seen an EEPROM on these models (unless I missed it), so I would look for a physical difference.
Offline Patrick.M
« Reply #46 on: April 06, 2018, 04:12:55 pm »
I must have done somthing wrong, solder splash, or somthing. Once I have the time and interest to play with this again, I'll givite it another go. Meanwhile, I saw absolutely, as I can be, no physical differences between the one 142A and three 152A PCBs. The only difference are subtle marking differences (suffixes) on the larg Xlinx chips. Referencing the data sheet for this Xlinx series has not been any help either.
Offline PrecisionAnalytic
« Reply #47 on: May 05, 2019, 08:14:53 am »
Earlier today I referenced this upgrade hack on the [HP-Agilent-Keysight-equipment] groups.io post since work was being performed on similar systems and that reminded me about the HP16533A hack into a 16534A by just swapping two resistors and was just verified with images:
https://groups.io/g/HP-Agilent-Keysight-equip…/message/96296
Alexandre just made an English post also:
https://tabajara-labs.blogspot.com/2019/05/repair-of-hp16533a-and-for-that-matter.html
When I need to, or use, the HP 16601A... I'll have to keep this in mind and plan to perform. Was waiting until I was sure about the SCSI Pi or other Emulator system I was going to make so I can use an IDE (PATA) or better newer drive, i.e. SATA. Probably can use an SD card since the data transfer rate isn't so high... though read write cycles, longevity and integrity was more the goal.
Anyone aware of any hacks for the 16601A?
I was thinking:
1. Making a SCSI emulator to update the drives
2. Wondering what the memory upgrade opportunities
3. Wondering about upgrading the motherboard
I haven't read into the later two capabilities yet and have read there aren't schematics for the HP 1653X or 16601A.
Offline schenkmi72
« Reply #48 on: June 24, 2019, 08:58:44 am »
Yatta!
I've try this on my 16740A but it didn't work for me. I already got an error while booting up and the self test says that it can't load the FPGA. I've tryied the 16742A ID resistores too but same issue. As it's a bit hard to acquire working 1674x  cards I don't like doing more experiments.
Cheers
Michael
