Author Topic: Hantek DDS3X25 Drivers  (Read 656 times)
Offline jazzalex
    • Soundjack
« on: September 10, 2020, 12:50:47 pm »
Hello all,
a couple of years ago I bought several DDS3X25 which worked great on Windows 7, however, on Windows 10 the hardware is not detected anymore.
Does anyone know if there is a recent driver for current Windows releases available ? At the Hantek website I did not find any yet.
Thanks a lot in advance,
best
Alex
« Last Edit: September 10, 2020, 12:55:02 pm by jazzalex »
Technology & Arts - http://www.carot.de
Offline coromonadalix
Re: Hantek DDS3X25 Drivers
« Reply #1 on: September 10, 2020, 05:19:26 pm »
Does the drivers have a valid signature ?   since windows 8.1  some drivers need to be signed .... if not you could try "compatibility mode" when installing them if they are done with an executable installer
Normally windows 10 is very good to handle some old stuff  BUT  lolll
Im running very old xp thru win7  software in windows 10  and it work very well
Does hardware manager show an exclamation mark ?   can you try to install them manually ?
Offline jazzalex
    • Soundjack
« Reply #2 on: September 11, 2020, 02:49:30 pm »
Yes and yes: There is an exclamation mark and I did install the drivers manually.
The signature is not the problem - it does the installation but when I try to launch the software it simply does not find the device.
If you have further ideas how to resolve please let me know.
Best
Alex
« Reply #3 on: September 11, 2020, 05:52:14 pm »
Point on the executable and open a "properties" window and use "compatibility mode"  ?  it  should work ?
you can choose between some os'es
Offline picburner
« Reply #4 on: September 11, 2020, 06:14:03 pm »
@ jazzalex:
I also have this old arbitrary waveform generator.
Unfortunately the drivers have not been updated since 2013.
Most likely it doesn't work anymore because your current Windows 10 is x64 while Windows 7 version was x86, in fact there are no x64 drivers for this device.
I use it with an old notebook with Windows XP...
« Last Edit: September 11, 2020, 06:25:04 pm by picburner »
Offline jazzalex
    • Soundjack
« Reply #5 on: September 12, 2020, 08:15:58 am »
Hej all, thanks a lot for the responses. In fact it does not launch even in compatibility mode. I will likely run it on an older machine or possibly get a new device.
Thanks for your help,
best
Alex
Offline ElektroQuark
    • ElektroQuark
« Reply #6 on: September 13, 2020, 10:47:05 am »
Hi Alex,
I have the DDS-3x25 working no problem on Windows 10 Pro x64.
Feel free to send mi your email by PM and I will send you the driver I have.
The following users thanked this post: jazzalex, coromonadalix
Offline jazzalex
    • Soundjack
« Reply #7 on: September 13, 2020, 08:04:34 pm »
Thanks so much - will send you a PM in a bit.
Best
Alex
    • ElektroQuark
« Reply #8 on: September 13, 2020, 08:25:10 pm »
You have mail ;)
Offline jazzalex
    • Soundjack
« Reply #9 on: September 15, 2020, 01:00:02 pm »
For some reasons it did not work out - will send you another PM with another mailaddress.
Thanks again,
best
Alex
    • ElektroQuark
« Reply #10 on: September 15, 2020, 06:43:25 pm »
Sent again.
Offline jazzalex
    • Soundjack
« Reply #11 on: September 20, 2020, 11:48:15 am »
Thanks to ElektroQuark the issue is resolved - thanks so much ! Now I am using the latest driver but I also had to disable the driver signature recognition process. Now it 's working fine !
