Author Topic: Blank screen on GM328 Tester after MCU re-programming  (Read 1587 times)
Offline sdancer75Topic starter
  • Country: gr
« on: March 27, 2019, 10:26:47 am »
I tried to re-program a problematic GM328 that was not possible to calibrate.
No matter what mega328_GM328 version I used from https://www.mikrocontroller.net/svnbrowser/transistortester/
I always get a white blank screen.  The fuses I used are: lfuse=0xF7 hfuse=0xD9 efuse=0xFF
I even tried the versions below without success.
GM328_EZM_v1.12k_r464_EN.zip
GM328_EZM_v1.12k_r508_EN.zip
GM328_EZM_v1.12k_r541.zip
Any recommendations?
Regards,
« Last Edit: March 27, 2019, 10:28:24 am by sdancer75 »
  • Country: gr
Re: Blank screen on GM328 Tester after MCU re-programming
« Reply #1 on: April 15, 2019, 05:09:23 pm »
The problem solved, I had to use the color version named "mega328_color_kit"
https://www.mikrocontroller.net/svnbrowser/transistortester/Software/trunk/mega328_color_kit/
