Author Topic: I bricked by Rigol DS2000  (Read 5760 times)
Online EEVblog
« on: April 09, 2013, 03:47:04 am »
Oops!  :palm:
Tried to downgrade the firmware from the dodgy version I have to the official 1.00.5 or whatever and all I get is a Rigol logo on boot.
 :scared:
Offline vk6zgo
Re: I bricked by Rigol DS2000
« Reply #1 on: April 09, 2013, 06:20:48 am »
OOOPS!! indeed!
Offline EV
« Reply #2 on: April 09, 2013, 07:25:15 am »
@Dave
Have you tried boot update during boot process as Drieg tells here:
https://www.eevblog.com/forum/blog/eevblog-369-rigol-ds2000-oscilloscope-playing-around/30/
Offline GeoffS
« Reply #3 on: April 09, 2013, 07:39:49 am »
That's the sort of thing I'd keep quiet about and if anyone asked why I wasn't using the scope, I'd just say it broke.  ;)
Online EEVblog
« Reply #4 on: April 09, 2013, 08:20:19 am »
@Dave
Yep, that fixed it!
Thanks to Drieg
Requoted here:
This bug has been fixed in FW 00.00.01.00.05 (there are still some bugs, axes in XY mode, trial options get expired after Self-Cal,..), so I suggest anyone with FW 01.00.02  to update to latest version. BUT, it is very IMPORTANT to do this update during boot process, not from the normal operation from the menu. Insert USB stick with the firmware, power-on the unit and pres shortly HELP button (immediately after POWER button before RIGOL logo appears). If it doesn't work, try again. If it still doesn't work, keep tying until it works. After you succeed, the SINGLE button will lights and update process will start shortly (CH1 LED blinks), after it's done, all LEDs light. Power-off, remove USB and power-on again.
All working good again with the original firmware
Offline EV
« Reply #5 on: April 09, 2013, 08:35:05 am »
Offline Hydrawerk
« Reply #6 on: April 09, 2013, 12:12:14 pm »
When Rigol doesn't publish their firmware online, I would expect those problems.  :-BROKE
Offline dr.diesel
« Reply #7 on: April 09, 2013, 12:23:28 pm »
That is odd, not to hijack, considering I'm about it buy how does one receive or be notified of updates?
Offline c4757p
  • adieu
« Reply #8 on: April 09, 2013, 12:46:04 pm »
They've done such a good job in general with the scopes, it's sad that they still can't get a firmware loader right. How hard is a checksum??
Offline olsenn
« Reply #9 on: April 09, 2013, 12:50:25 pm »
Recent firmware annoyance aside, how do you find the DS2022 compares to your MSOX3000 scope Dave?
Offline rbola35618
« Reply #10 on: April 09, 2013, 01:01:25 pm »
Dave,
Do a Rigol DS2000 comparision with the Agilent that you have to see how the Rigol stacks up. I would suggest to show a Video signal since it is probably the most complex signal that one can use. It has high and low frequencies (digital sort of, horizontal and vertical sync) and analog. I would be interest how they compare. I would suspect the Agilent would win.
Robert
Offline Hydrawerk
« Reply #11 on: April 09, 2013, 01:51:32 pm »
They are too different.
MSOX3000: only 4Mpts memory, 1000 000 waveforms/sec, but not more sensitive than real 4mV/div
DS2000: 56Mpts memory, sometimes up to 50 000 waveforms/sec, probably real 0,5mV/div
Each scope is good for someone else. But the Agilent will probably last longer. It has 5-year warranty
Online EEVblog
« Reply #12 on: April 09, 2013, 02:23:07 pm »
Your local dealer. But you'd likely have to ask.
Online EEVblog
« Reply #13 on: April 09, 2013, 02:29:09 pm »
Apples and oranges.
One is faster and mixed signal, with real hardware serial decoding, and the function gen is quite useful, as are the training signals. But I prefer the deeper memory, and vertical amp on the Rigol, and it has better features overall.
But I prefer the working and feel of the Agilent. The Rigol feels like it has too many bells and whistles that get in the way for day to day use.
Offline Salas
  • Country: gr
« Reply #14 on: April 09, 2013, 04:01:36 pm »
Only talking comparisons with a 3000X speaks volumes of Rigol's VFM I guess.
Offline ve7xen
    • VE7XEN Blog
« Reply #15 on: April 09, 2013, 06:00:14 pm »
Is this (supposed to be) available on the DS2072? Mine only goes to 2mV/div.
73 de VE7XEN
Offline Galaxyrise
« Reply #16 on: April 10, 2013, 05:40:35 am »
The datasheet certainly doesn't mention a difference.  Make sure you've got the channel set to 1x.  If it were set to 5x, then the lowest setting would be labelled 2.5mv.
I am but an egg
Offline ve7xen
    • VE7XEN Blog
« Reply #17 on: April 10, 2013, 06:40:56 am »
Doi. Of course. I had a 10X probe connected.
Still haven't gotten used to the scope correcting for that automatically. I forget every time I hook up a 1X signal to it.
73 de VE7XEN
