Well, after replacing all the capacitors and calibrating the machine, I went back to the beginning of the calibration... just to check again. When I got to step #2, the Test 1 button no longer worked. It doesn't seem to do anything at all now. It won't calibrate and it's as if the button no longer works at all. So, my new-old tube tester is now a door stop.
I also notice that the two 5W resistors on the board with all the calibration pots are overly hot as well.
Any thoughts on how to figure out what I could've broken?
Thank you,
- Wil
