Author Topic: Measureing ripple voltage of DC/DC converter with a DS1052E?  (Read 1224 times)
Offline jb79Topic starter
  • Country: at
« on: January 25, 2017, 04:30:07 pm »
Hello!
I've got a DS1052E with the two original probes and I would like to measure the ripple voltage of a small DC/DC converter with a switching frequency of about 500kHz (as far as I know). Here's the converter: https://www.aliexpress.com/item/10-PCS-Mini-DC-DC-12-24V-to-5V3A-Step-Down-Module-Power-Supply-Module-Converter/32738372200.html
The converter should transfer 15-16V to 3,3V to supply power an ATXMEGA128 and some chips around it, normally about 100mA. For tests I use a 4S Lipo as voltage source that is charged to about 16V.
I allready tried it with the DS1052E but as I found out, it looks like the ripple voltage at these low currents is about 10-15mV or lower, it seems that is really low for the DS1052E. I used AC coupling for CH1 and trigger.
Switching the probe to 1:1 didn't solve the problem, the result looks like crap.
I also have got an old HP3478A multimeter but I think it's frequency range is only 300kHz, so that also won't help me.
Any ideas how I could measure the ripple more precise with my equipment?
« Last Edit: January 25, 2017, 04:31:41 pm by jb79 »
Offline amitchell
The following users thanked this post: paf, nugglix
  • Country: at
Re: Measureing ripple voltage of DC/DC converter with a DS1052E?
« Reply #2 on: January 26, 2017, 09:16:33 am »
Hi!
Thank you, there are some good hints in this document.
