Products => Test Equipment => Topic started by: Dragony on March 20, 2017, 10:14:10 am
Title: I need a 1 GHz scope! But which one???
Post by: Dragony on March 20, 2017, 10:14:10 am
For RF experiments I want to purchase a new scope with 1 GHz BW.
Whats the most recent one, which doesnt cost like $20000?
Title: Re: I need a 1 GHz scope! But which one???
Post by: tggzzz on March 20, 2017, 10:27:24 am
What do you want to measure with the scope? For RF work, a scope is usually the wrong tool.
Post by: AndyC_772 on March 20, 2017, 11:02:06 am
I have an MSO-X3104A, which wasn't $20,000, but nor is it as capable in some ways as other 1GHz+ scopes I've used. I like it a lot, and it suits my needs well, but since you're after a relatively specialist instrument, it's definitely worth exploring how you plan to use it first.
Post by: Dragony on March 20, 2017, 11:03:36 am
Why???????
What is the right tool for RF analysis like field strength, FFT, etc?
Post by: Ammar on March 20, 2017, 11:04:20 am
Just ordered a Lecroy 1GHz 6100A second hand. Make sure you can try it first, see if it actually meets your needs.
Post by: coppice on March 20, 2017, 11:07:59 am
Why???????
If you need to ask that question you probably need to do more work before buying instruments. For almost all RF work the first priority is a good spectrum analyser. The second is tools which can help with modulation analysis. Somewhere down the list comes a good scope. A cheap scope is fine for most RF people.
Post by: mikeselectricstuff on March 20, 2017, 11:08:12 am
Why???????
If you have to ask that, you are probably not ready to make a 4+figure purchase
Post by: nfmax on March 20, 2017, 11:16:49 am
Why???????
...except possibly from me  ;)
Post by: tggzzz on March 20, 2017, 03:13:01 pm
Why???????
You will benefit from:
Post by: Howardlong on March 20, 2017, 03:23:41 pm
Why???????
Up to 1GHz, a decent comms test set which includes RF signal generator, power meter, SNR measurements and spectrum analyser in one box is a very useful bit of kit for RF. Some will also allow swept measurements for filter alignment.
For RF, time spent with the scope is surprisingly low.
