Author Topic: I need a basic and cheap clamp meter with mA scale.  (Read 711 times)
Offline viperTopic starter
« on: August 08, 2024, 03:39:44 am »
I am doing some repair work where I need resolution down to 1mA.  Perfect accuracy is likely not needed for this, but a reasonable meter would be nice.  Of all my Flukes, I don't have one that can do this.  I can't break the wire for a more accurate DMM test.
Of the ones I have looked at so far, I am at like $400!  Of course I found variants on fleabay for $50 but who knows what they will do.
Any help would be great!  Probably use this meter only a few times.  Have looked at stuff like Klein, but no luck.
Online J-R
Re: I need a basic and cheap clamp meter with mA scale.
« Reply #2 on: August 08, 2024, 05:03:50 am »
I'd suggest the clamp accessory path, because you can use them with a scope as well.
Offline wasedadoc
« Reply #3 on: August 08, 2024, 10:28:47 am »
AC and DC or AC only?
Offline Postal2
« Reply #4 on: August 08, 2024, 01:01:41 pm »
.... I need resolution down to 1mA.  .....
Wrap your thin 1mA wire around your finger 10 times and clamp the entire bundle.
« Reply #5 on: August 08, 2024, 03:00:49 pm »
Only working AC right now, but I'd be more inclined to find or buy an AC/DC meter as I'd have plenty more uses on the DC side.  Always chasing automotive bugs down.
Offline David Hess
  • DavidH
« Reply #6 on: August 08, 2024, 04:43:52 pm »
I have been considering the B&K 316 AC/DC clamp meter which has 1 milliamp resolution.
https://www.bkprecision.com/products/multimeters/316
« Reply #7 on: August 08, 2024, 05:24:54 pm »
Appreciate the help guys.  I have an Owon coming.  Probably not the absolute best but we have one of their scopes and can't really complain too much with their quality vs cost.  If I end up using it more frequent, I will look towards a better meter.
