Author Topic: I need a better (cheap) probe(holder) for measuring signals on arbitrary devices  (Read 30139 times)
Offline capt bullshot
Wouldn't it be simpler to just solder a small wire? Probably takes a lot less than trying to position some whacky probe holder.
My colleagues do this with sometimes 10-15CM wires. Signal integrity is a magic world.
I prefer soldering a small, 1-2mm hook. Best is a 1K resistor to SMA, SMA cable, BNC adapter scope, 50Ohm. 1:20.
Do you happen to work for the same company as I do?
I've seen this "technique" (the long wires) way too often.
« Last Edit: October 09, 2018, 07:52:40 pm by capt bullshot »
Offline Performa01
  • Country: at
... this would already make three of us! :-DD
seriously though, at least for the two of us, the chance we both work for the same enterprise isn't even that low...
Online 2N3055
  • Country: hr
What else would you do ?  ^-^
+ on both wire hook and 1k and 450 ohm resistors terminated into 50 ohm scope...
« Last Edit: October 09, 2018, 09:23:18 pm by 2N3055 »
Dr. Richard W. Hamming
Offline bostonman
I'm digging up an old thread rather than start a new one.
I like the Harbor Freight item (https://www.harborfreight.com/multipositional-magnetic-base-with-fine-adjustment-5645.html), but wondering if anyone has made a 3D holder?
My needs would be for various scope probes and meter leads, so I'd need something that can adapt to different lead types.
Recently I began repairing a board with 0402 components and need a spare hand. Something that would hold a probe lead and/or multi meter leads would be great.
Offline hvontres
You might want to check out Noga arms (https://www.noga.com/Products/hold/Holding%20System)  (or one of the knockoffs). I haven't used mine to hold probes, but for getting dial indicators into strange positions quickly, they can't be beat.
Henry von Tresckow
I am not an EE, but I play one in the Garage
Offline bostonman
I didn’t see prices. Did I miss something? From looking at their products, I’d guess they aren’t cheap.
Offline TopQuark
  • Country: hk
I use these surgical locking clamp thingys. Cheap, universal and effective.
Offline Martin72
  • Testfield Technician
