Products => Test Equipment => Topic started by: Frozen001 on October 30, 2020, 06:14:53 pm
Title: I thikn I bricked ADS-1102CAL
Post by: Frozen001 on October 30, 2020, 06:14:53 pm
Tried to update FW on my ADS-1102CAL.  File pulled from here:
https://www.eevblog.com/forum/testgear/atten-lt-gt-siglent-conversionscrossflashes-do-you-still-have-problems/msg3058828/#msg3058828 (https://www.eevblog.com/forum/testgear/atten-lt-gt-siglent-conversionscrossflashes-do-you-still-have-problems/msg3058828/#msg3058828)
ATTEN_ADS1102C_2.07.02.10R5_ProdId_79_ISP
Flash seemed to work fine.  Power cycled when complete, now all buttons light up and display is blank
Any chance of fixing this?
Title: Re: I thikn I bricked ADS-1102CAL
Post by: uski on October 31, 2020, 04:06:59 am
I advise that you reply in the thread where you got the files from, so that people experienced with them will be able to help you.
In parallel if you feel like it, you can disassemble your scope and see where the flash image is stored. If it is stored in a serial flash chip you could maybe get someone to get a dump and flash the dump to yours. Or maybe you can spot a JTAG interface and use that.
But again, start by asking in the thread you linked
Good luck !
Post by: Frozen001 on October 31, 2020, 03:31:13 pm
Thanks hopefully someone can help out.  Cracked the case and this old, so I am not really holding out much hope at this point, March 2011 date sticker on the inside sheet metal.
