I get a piece of test equipment that will allow me to monitor several voltage rails as part of an automated test. I just need to measure DC levels. I don't care if it's USB, serial, network, or other. Multiple channels would be nice, but if it's only one channel, I can buy multiple.I see stuff like the USBee DX, but it's got way more features than I need and the cost is way too high, especially when you need more than 2 channels:http://www.usbee.com/dx.htmlAny tips?
Quote from: Russ.Dill@gmail.com on June 11, 2013, 07:51:08 pmI get a piece of test equipment that will allow me to monitor several voltage rails as part of an automated test. I just need to measure DC levels. I don't care if it's USB, serial, network, or other. Multiple channels would be nice, but if it's only one channel, I can buy multiple.http://www.mccdaq.com/Will sell you USB data acquisition modules starting at $99 for 8 single ended 12 bit channels.
Quote from: Russ.Dill@gmail.com on June 11, 2013, 07:51:08 pmI get a piece of test equipment that will allow me to monitor several voltage rails as part of an automated test. I just need to measure DC levels. I don't care if it's USB, serial, network, or other. Multiple channels would be nice, but if it's only one channel, I can buy multiple.I see stuff like the USBee DX, but it's got way more features than I need and the cost is way too high, especially when you need more than 2 channels:http://www.usbee.com/dx.htmlAny tips?That is QUITE pricey for what it is IMHO. I am not size is an issue but there are a variety of scanning DMMs out there. You don't mention, do you have a required precision or accuracy, minimum number of channels, voltage range?
