Author Topic: Repair of a Tektronix DPO4034 with faulty main board  (Read 3242 times)
Offline elektronchikaTopic starter
  • Country: bg
    • Elektronchika's blog
« on: September 17, 2015, 10:00:13 am »
Hello everyone,
I'm an electronics engineer, and I like to also do some staff at home. I'm offered to buy a Tektronix DPO4034 with faulty main board. The scope starts but cannot boot and reports a bus failure with one of the acquisition chips. The current owner says this is a main board problem. I wonder if someone else had a similar problem, how he solved it? Or what do you think about repairing this scope at home? I ask all you guys, before buying the scope for advise.
Best regards,
Lazar
Offline nctnico
Re: Repair of a Tektronix DPO4034 with faulty main board
« Reply #1 on: September 17, 2015, 10:07:09 am »
If you can get it for free go for it, otherwise just buy a Rigol 1000Z series.
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #2 on: September 17, 2015, 10:08:31 am »
Depends on price :)
  • Country: bg
« Reply #3 on: September 17, 2015, 10:09:16 am »
It's not for free, it's still expensive - more than 3000 Euro. But I can try to reduce the price, once I think it's wordy.
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #4 on: September 17, 2015, 10:12:07 am »
Then it's worthless.
Offline nctnico
« Reply #5 on: September 17, 2015, 10:16:53 am »
I agree. With such a fault I wouldn't spend more than 200 euro on it just for the fun and learning (I have a lot of experience with hacking/repairing test gear).
Offline Orange
« Reply #6 on: September 17, 2015, 10:45:23 am »
The chances that you can repair it are pretty slim. Tek uses always custom chips and hybrids. Usually unobtainable stuff, unless you have a donor scope.
3000 euros for a defect Tek is absurd, even 200 euros is too much to take the risk.
Offline Wuerstchenhund
  • Able to drop by occasionally only
« Reply #7 on: September 17, 2015, 11:25:59 am »
I agree with the others, €3000 for a defective 300MHz DPO4k are pretty much excessive. There aren't many user-serviceable parts inside, so you'd probably have to send it to Tek for repair, which will be expensive.
I'd give it a shot if you can get it for €500 or less and send it for Tek for estimate/repair, and then the overall investment may be worth the effort. If it's more than €500 then better buy something else.
Offline lowimpedance
  • Watts in an ohm?
« Reply #8 on: September 17, 2015, 11:49:35 am »
 A number of years back work had a DPO4k fail and that cost $5000 to fix,(cost $15K new),  and all Tek did was change the main board and calibrate.
If it fails again it goes into the bin. Frankly if you have the cash to spend buy something new and don't touch this landfill.
