Author Topic: Identify test point connector Philips PM5193  (Read 492 times)
Offline gmac34Topic starter
  • Country: no
« on: March 28, 2023, 09:44:18 pm »
Hi, I wanted to go trough the calibration procedure for my Philips function generator, but this involves hooking up to a series of test points that have a coaxial connector that I cannot recognise, the manual mentions that the service kit would include cable adaptors but doesn't seem to mention the connectors in the part list.
Before I MacGyver something, does someone recognise them, so I can search for a matching connector?
Thanks !
Offline Kim Christensen
Re: Identify test point connector Philips PM5193
« Reply #1 on: March 28, 2023, 09:55:22 pm »
It almost looks like something you could insert a scope probe into.
  • Country: no
« Reply #2 on: March 28, 2023, 10:25:24 pm »
I thought that as well, the inner diameter of the ground is 3.5mm which is a standard probe size, but the center pin is not a "tube", it's just a pin, this on the board appear to be the male side of this standard, so a probe would not mate there properly.
