If I were going to buy it for myself on my personal usage, I will probably buy Brymen but if I were going to buy it for earning money, then it depends on the situation for buying Fluke or Brymen but it is easily to imagine I will be buying Fluke on many occasion.
The test equipment like handheld DMM are used for both as own usage (hobby, your own projects and etc) and for the purpose for earning revenue and this makes situation complex.
I like Brymen and derivative of Bryman such as Amprobe (it is Sanwa PC7000 in Japan) because the price is better for the specs and built quality, input protection, quality of LCD, speed of auto range, speed of update rate, speed of continuity test, quality of test leads and etc are reasonable (may not be the best but it is reasonable) and it makes me feel that Brymen knows what they need to do to make a good multimeter, compare to many other cheaply made ones.
But if I have to select a multimeter for earning income or for the company then it is really depends on the situation.
For example,
(*)If I am an OEM factory owner and in the position to find the manufacture who is seeking for a good factory, then I have to promote or demonstrate the goodness of my factory. If my factory was using like Fluke which is well known top brand multimeter or using Brymen, then the later will probably consume my effort for explaining extra.
(*)If my organization bought heavy industry equipment like power plant or military equipment made in US (which is the case in Japan), then the almost all the manuals for maintenances will be written based on using Fluke. Then the selection becomes whether to buy Fluke 83/87 or translate all the manuals for the Bryman.
(*)If I was working as an engineer in the large electronic company and most of the top management is not engineering background, then I have to consider when making evaluation reports which will be less hustle if the data will be measured by Fluke or Brymen.
(*)If I were employee as a service engineer to frequently visit customer’s sites to measure very expensive machineries, then I have to consider which will be easier to have better credibility from the customer if I were using Fluke or Brymen.
(*)If I were in a position for procure department for the company and wanted to secure my job for my life as much as possible, then which will have less blames if anything happens on the mulimeters between Fluke or Brymen.
There must be more examples, so there are many reasons for selecting Fluke does have good reasons.
If it was for my *own* use, I will pick Brymen and ask my friends the Fluke 87V for a present for me because it is just a nice superb mutimeter want to have it someday.
(Am I asking too much?)
