Author Topic: If you only had one meter?  (Read 13798 times)
Offline 4thDoctorWhoFan
Re: If you only had one meter?
« Reply #100 on: April 22, 2023, 04:36:36 pm »
I bought a Beckman Tech 310 new in 1980.   It still works and is still in spec.   It was about $140 from Mouser, a huge amount of money for me at the time.   That's $500 adjusted for inflation.
I keep the 310 in my desk at work.  I still use it ocassionaly.
I have a Beckman HD110 in the yellow case.  I also still use it every now and then.  Not sure why, but I like it.
Offline NoisyBoy
« Reply #101 on: April 22, 2023, 06:22:47 pm »
For the sake of easy repair service, lifetime warranty, and calibration services, I would pick my Fluke 179.  I like its smaller form factor for handheld uses.
Offline vk6zgo
« Reply #102 on: April 23, 2023, 12:55:00 am »
Liar! Only Flukes can do that!!
(froth)
;D    The orginal made in California Beckman DMMs were very durable.
Telecom Aust standardised on the Beckman in the 1970s, at least in the RadioComms & Broadcast sections.
I think they were put off Fluke by some of their early bench meters.
At my depot, we had a quite early one which was solid enough, & although not trouble free, was easily fixable, & a slightly newer one which was a total pig.
The old "Beckpersons" were rugged & reliable----what more could you want in a handheld DMM?
I never had a Fluke handheld DMM till I left & went to the Private Sector & got the 77.
Hiding at the Transmitter site was one of the Flukes with side push button switches, which I never liked, as one button was missing.
I had a "Dick Smith" clone with the same switch idea, although much more crappily done.
The "convenience" of side buttons never was a convincing argument to me, especially as the 77 offered pretty much the same advantage of "one handed" setting whilst using a conventional rotary switch.
Offline tooki
« Reply #103 on: April 29, 2023, 05:01:18 pm »
It even wins without any probes connected!
Wait, is that a mains breakout box? With unshrouded plugs?...in those colours? OK, must stop as I'm starting to sound like some kind of comedy sketch, but that looks a bit "how ya doin", even by my generally quite relaxed standards.
Huh? I see only shrouded plugs.
Offline Fungus
« Reply #104 on: April 29, 2023, 05:12:55 pm »
Huh?  :-//
Offline slurry
« Reply #105 on: April 29, 2023, 05:22:22 pm »
Metrix MTX3293 has all that and some...
I had one of those MTX in the past, i like the display and now I have the MX5292-BT, new in box, capable yes absolutely.
I really tried but I can not get accustomed to the user interface at all! - so i´m thinking of selling it and buying a Hioki DT4282.
Returning to the question,
if ease of use and small size is important i think the Fluke 17B+ is a great companion for most electronics work.
If i have the money, a Fluke 289 is a no-brainer, i still regret selling mine.
If you are on a budget, i like my Brymen BM867s, it is cheaper than BM869s and still have most of the functions.
« Last Edit: April 29, 2023, 05:23:53 pm by slurry »
Offline Andrew_Debbie
« Reply #106 on: May 02, 2023, 08:32:10 am »
The HD110 is a ruggedized 310. Absolute tank.  I belive they were waterproof too.
Beckman sold their DMM division to Emerson Electric and the brand name changed to Beckman Industrial.    Eventually everything moved to Taiwan.  I belive production went first followed  by design, but I could be mistaken.    I think Emerson moved the brand downmarket in the 1990s but that could be a memory error :)
Emerson changed what was printed on the back side.   I'd be interesed to know what yours has.
« Last Edit: May 02, 2023, 08:36:24 am by Andrew_Debbie »
Offline tooki
« Reply #107 on: May 02, 2023, 04:10:08 pm »
Huh?  :-//
Yeah but that's not metal. (IMHO obviously so, since it also doesn't look like a banana plug, but like a smooth cylinder.)
Anyhow, those are Hirschmann retractable-shroud banana plugs. (The shroud in those is spring-loaded, but is locked in the shrouded position. A release button on the side of the plug allows the shroud to be retracted to the unshrouded position.)
See attached pictures.
This is the product line: https://www.sks-kontakt.de/en/test-measurement/products/4-mm-sliding-sleeve-system
LMAO! This line from the product page for the assembled test leads is glorious: "Contact protected test lead on both sides sprung plug Ø 4 mm, insulated by latching and sprung insulated, which is only released by pressure on the lateral locking spring, and rigid socket Ø 4 mm to the far pluginess."
(In the original German, the sentence translates to "... and rigid Ø 4 mm socket for stacking.")
Offline kripton2035
« Reply #108 on: May 02, 2023, 05:21:56 pm »
fluke 867B
The following users thanked this post: shakalnokturn
Offline Fungus
« Reply #109 on: May 02, 2023, 07:55:39 pm »
fluke 867B
Never seen that one before, but, yeah... looks like a fun meter.
Offline kripton2035
« Reply #110 on: May 02, 2023, 08:23:07 pm »
planning to replace it with some owon hds22xx but not sure it will be as good as the 867B ...
Offline shakalnokturn
« Reply #111 on: May 02, 2023, 09:54:34 pm »
The scope section can only be better. Then there's the DMM, UI, build quality...
Offline David Hess
  • DavidH
« Reply #112 on: May 03, 2023, 09:35:15 pm »
I would love to have a meter with good thermocouple measurement.  Most use those adapters which compromise accuracy.  I guess if you want something better, you just get a dedicated thermocouple meter.  I get my best results with Fluke 80TK thermocouple adapters.
