Author Topic: Adding option 488 to a Fluke/Gigatronics 6060B  (Read 602 times)
Offline ZGoodeTopic starter
  • Grad student by day, equipment nerd also by day
« on: March 25, 2024, 10:42:58 pm »
I recently acquired a Fluke 6060B that unfortunately did not have option 488 installed, so I decided to go about replicating a replacement board for that.  I got lucky since the GPIB chip it relies on is a UPD7210, of which I have a few NAT7210's on hand (a drop in replacement).  This board design should be also compatible with the 6060A, 6061A/B, and possibly a few other models.
I have not tested this yet, as I just finished the eCAD design and have just sent it to JLCPCB.  I will post an update when the board is received and tested.
A weird quirk I saw in the various manual revisions I found is that sometimes it lists a 273 instead of a 373.  Although I am assuming that is a typo and they meant 373 since the 273 is only mentioned once in one revision.
Edit: removed error files, refer to my more recent reply for up to date gerbers and schematics.
« Last Edit: April 20, 2024, 03:16:03 am by ZGoode »
Re: Adding option 488 to a Fluke/Gigatronics 6060B
« Reply #1 on: April 18, 2024, 03:24:06 am »
I found one minor mistake with how the DIP switch was connected, I have updated it.
Offline coromonadalix
« Reply #2 on: April 18, 2024, 04:01:51 pm »
better remove the "bad" files,  go in the attachements and uncheck them ...
The following users thanked this post: ZGoode
