Author Topic: Incorrect values ​​in 0.1uf capacitor measurement  (Read 1106 times)
Offline TA3UISTopic starter
  • Country: tr
« on: December 02, 2024, 07:58:07 am »
Why do I get such incorrect values ​​when measuring a 0.1uf capacitor?
I tried with 7 different 0.1uf capacitors and always get absurd values.
Some of the photos are crooked, I tried but couldn't fix them. Sorry.
« Last Edit: December 02, 2024, 08:22:42 am by TA3UIS »
Offline TheDefpom
  • YouTuber Nerd - I Fix Stuff
    • The Defpom's Channel
Re: Incorrect values ​​in 0.1uf capacitor measurement
« Reply #1 on: December 02, 2024, 08:16:43 am »
Have you done a calibration of the unit with that test fixture ? you should do that first (will ask for a short and an open cal)
Cheers Scott
  • Country: tr
« Reply #2 on: December 02, 2024, 08:21:23 am »
Yes, the calibration process was completed successfully every time.
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #3 on: December 02, 2024, 08:31:47 am »
Are you quite sure those are 0.1uF caps? Haven't seen all that many 100nF electolyte caps...
The following users thanked this post: Someone, thm_w, Kean
Offline NE666
« Reply #4 on: December 02, 2024, 08:37:46 am »
And to add what has been already asked r.e. their actual value,  what is the source of these 7 'different' capacitors? That is to say, did you buy them together as a batch/bag from the same supplier? Or are these 7 fully independent data points? How old are they?
Do you have any other meter you could use as a sanity check? e.g. multimeter with a capacitance range.
What does your DE-5000 measure for other value capacitors you have to hand?
  • Country: tr
« Reply #5 on: December 02, 2024, 08:38:51 am »
Of course I'm sure about what I'm measuring.
That's another test.
  • Country: tr
« Reply #6 on: December 02, 2024, 08:49:21 am »
Yes, they are all the same brand and were purchased from a single supplier. Do you think the 0.1uf capacitors are defective?
  • Country: tr
« Reply #7 on: December 02, 2024, 08:54:21 am »
These are the measurements of the 0.22uF capacitor
Offline NE666
« Reply #8 on: December 02, 2024, 08:59:05 am »
And/or mis-labelled, yes.  The probability of that being the case depends strongly on the manufacturer, the supplier and your source.
If they are known brand, sourced from a reputable supplier (e.g. digikey, mouser, farnell, RS, etc. etc.) then it would be an odd thing. If they are from 'the internet', then very much more likely.
  • Country: tr
« Reply #9 on: December 02, 2024, 09:00:48 am »
These are the 0.47uF capacitor measurements
Offline NE666
« Reply #10 on: December 02, 2024, 09:04:56 am »
Well, that suggests that your meters are in broad agreement, limited by their own resolution/accuracy/calibration/test freq.
Hence, your "0.1" capacitors are almost certainly junk.
The following users thanked this post: Kean
  • Country: tr
« Reply #11 on: December 02, 2024, 09:08:02 am »
These are the 1uF capacitor measurements
  • Country: tr
« Reply #12 on: December 02, 2024, 09:13:16 am »
I guess the 0.1uF ones are garbage as you said. Maybe the 0.22uF ones too?
Here is another 0.1uF capacitor measurement from the same series.
Offline Atlan
  • Country: sk
« Reply #13 on: December 02, 2024, 09:32:36 am »
First, try to shape the capacitors a little under voltage, and discharge them before measuring.  If it's the small low-profile capacitors, I don't use them as a rule, since they hit me with their leakage current.  They don't even have vitality, who knows what - especially if it's not a well-known brand.
FNIRSI 1013D Always provide a picture or video with the problem where the parameters of the oscilloscope are visible, and a picture of the diagnostic screen with the values.
  • Country: tr
« Reply #14 on: December 02, 2024, 09:35:05 am »
I will try this when I have time.
Offline indman
  • Country: by
« Reply #15 on: December 02, 2024, 12:01:03 pm »
Yes, these capacitors are of poor quality. Look at the pictures I took of similar specimens.
In your photos, in addition to the wrong capacitance, these capacitors have a very high loss factor D, which is 10 times the same parameter of a serviceable one.
  • Country: tr
« Reply #16 on: December 02, 2024, 12:15:39 pm »
The 0.1uf capacitors I have are also from the same brand. The ones I have are garbage...
« Reply #17 on: December 02, 2024, 12:26:39 pm »
Chengx, a clone of the Chongx capacitors, which are a poor clone of pretty much any other of a million other manufacturers. If you need to buy sub 1 uF capacitors do not ever buy electrolytics, instead buy polyester or polypropylene. Pretty much any film capacitor will be better in all respects other than size, and stay away from ceramic capacitors as well, unless you get NPO types, the standard and common X7R types have both a massive tolerance variation, plus also aregoing to change capacitance with voltage applied across them as well.
But those ones apply close to rated voltage (you can put them all in parallel to do so) via a 10k resistor, so as to limit current, and also measure leakage, and leave them powered up for 48 hours to reform, and you will see a big change, though these cheap and nasty capacitors are best tossed and replaced with decent brand name types, like Nichicon, Vishay or Matsushita, though you will pay a premium for them, but they will last a long time in service, and have good performance.
  • Country: tr
« Reply #18 on: December 02, 2024, 12:47:47 pm »
The ones I have are Cheng brand. I think they are the trash of trash
Online wraper
  • Country: lv
« Reply #19 on: December 02, 2024, 01:00:39 pm »
The original is Chang (Changzhou Huawei Electronics, funded in 1987), the rest are knockoff brands of it. ChengX (Chengxing Electronic) eventually grew up into a quite large company (probably larger than Chang) with proper product range and datasheets, the rest are still one hung low shops, including Chongx. One on the photo is Cheng with no X.
« Last Edit: December 02, 2024, 01:09:08 pm by wraper »
Offline indman
  • Country: by
« Reply #20 on: December 02, 2024, 01:01:36 pm »
Yes, it is better not to use capacitors from this company - there are too many defects and low quality products.
Online Aldo22
« Reply #21 on: December 02, 2024, 01:13:47 pm »
I once bought some electrolytic capacitors in a big plastic bag from AE.
They are certainly of cheap quality, but they are not as bad as yours.
I have never seen so much deviation in new ones.
In the attachment for comparison 0.22uF from my bag (my lowest value for electrolytic capacitors).
« Last Edit: December 02, 2024, 01:15:56 pm by Aldo22 »
Online wraper
  • Country: lv
« Reply #22 on: December 02, 2024, 01:22:05 pm »
Ltec is a decent Taiwanese manufacturer actually.
The following users thanked this post: thm_w, Aldo22
  • Country: tr
« Reply #23 on: December 02, 2024, 01:28:03 pm »
The problem with Cheng or Cneng brand capacitors seems to be more common with the 0.1uF and a little bit with the 0.22uF capacities. Are they labeled incorrectly?
« Last Edit: December 02, 2024, 01:33:37 pm by TA3UIS »
Offline indman
  • Country: by
« Reply #24 on: December 02, 2024, 02:00:27 pm »
It's not a matter of labeling, read what I and others wrote to you before. Lots of fakes and defects!!!
« Last Edit: December 02, 2024, 02:35:08 pm by indman »
