Thank you for the thoughts. Other than this amp that I am building, my needs rarely go over 60Vdc, so the higher voltages aren't a regular occurrence. The Fluke 89 has been a very dependable meter for me, but I bought it used several years ago before DMM prices skyrocketed. Battery life (4xAA) hasn't been an issue for me with it, and I have spare battery contacts for it. I use Duracells in it. I had been looking at used Flukes, but find that one of the Brymens that I am looking at is often cheaper that these are used. Some of the used Flukes appear to have had a hard life as well.I also don't need PC interfaces, bar graphs or any of that, so maybe I am looking at more meter than I need as I only use these for hobbyist purposes (audio equipment mainly). The prices in the $150 USD range is acceptable for something that will give dependable readings, normally DCV or resistance measurements (matching), as well as uA/mA if I am doing BJT matching.Regarding counts, I'm not knowledgeable enough on this to know what the benefits/drawbacks are. I guess I would need to do a LOT more reading on this board to begin to understand the subject. Looking up the Fluke 89 I have, it states 50,000 count for the primary display, which has certainly been acceptable for my use.
