Author Topic: Info and help on the Meguro MO-1254A Oscilloscope  (Read 642 times)
Offline IgacTopic starter
  • Country: cs
« on: January 18, 2024, 02:21:03 pm »
Hello, I'm new-ish to electronics and found a good deal for a Meguro MO-1254A scope.
Does anyone have experience using these scopes do they come with off-the-rack hardware, maybe some tips or manuals?
The scope is very well-priced for my region so I'm thinking about pulling the trigger.
Thank you guys in advance!
Offline Lochstreifen
Re: Info and help on the Meguro MO-1254A Oscilloscope
« Reply #1 on: January 19, 2024, 06:42:45 pm »
It's a 50 MHz analog CRO with second time base and a well thought out user Interface.
It was also rebranded as Gould OS 350, Elenco and Heathkit SO-4251.
You can find the manual for the otherwise identical 40 MHz version here
https://elektrotanya.com/meguro_mo1253_40mhz_dual_channel_oscilloscope_sm.pdf/download.html
