Author Topic: anyone seen a review of the cheap 100X differential probe from Aliexpress  (Read 513 times)
Offline OddTopic starter
  • Country: no
You can easily find them here:
https://www.aliexpress.com/w/wholesale-10M-Oscilloscope-Differential-Probe.html
I am looking for some review/test, a differential probe does not *need* to cost a lot, as there is nothing special inside, and I am curious about this one, how it compares to the well known Micsig and such.
Offline xtech
Re: anyone seen a review of the cheap 100X differential probe from Aliexpress
« Reply #1 on: December 14, 2024, 04:22:37 pm »
That aliexpress diff probe is low voltage one (max 40Vpp). For micsig you have 700Vpp - you pay for your safety ;) Also bandwidth is 10x smaller.
The following users thanked this post: Odd
Offline stj
« Reply #2 on: December 14, 2024, 04:27:27 pm »
it looks risky,
i would want a plastic outer housing and plastic or shrouded BNC's incase it accidentally grounds against something!
Online nctnico
« Reply #3 on: December 14, 2024, 04:33:17 pm »
This one is intended to bring small signals into an oscilloscope (hence the 10x and 100x gain). Not for probing high voltages. This doen't make it useless but it just serves an entirely different purpose which makes it not comparable to the high voltage differential probes Micsig makes.
« Last Edit: December 14, 2024, 04:37:16 pm by nctnico »
Online kripton2035
« Reply #4 on: December 14, 2024, 05:45:32 pm »
I bought a used high voltage diff probe for almost the price of this new low voltage one...
just post alerts on ebay or your local craiglist and be a little patient.
Online nctnico
« Reply #6 on: December 14, 2024, 08:48:38 pm »
Hello,
but there is something about it:
https://www.eevblog.com/forum/testgear/cheap-chinese-oscilloscope-preamp-tear-downreview-is-it-any-good/msg5712421/#msg5712421
Thanks for bringing that up! The bottom line is that these devices are crap. Having it battery powered only to completely screw up the noise floor by having a switching PSU inside  :palm:
The following users thanked this post: egonotto, Odd
