Author Topic: Rigol MSO2000A-S with signal gen hacking  (Read 2734 times)
Offline depejeTopic starter
« on: September 12, 2014, 11:10:15 am »
Does anyone know whether the MSO2000A-S scopes with signal generator can also be hacked like described in this topic? Does this hack also enable the function gen in an MSO2000A which doesn't come with the generator? Is the hardware any different between the MSO2000A and the MSO2000A-S?
Re: Rigol MSO2000A-S with signal gen hacking
« Reply #1 on: September 23, 2014, 08:55:10 pm »
To reply my own question: yes, this also works for the MSO2072A-S. Although the 300MHz key doesn't upgrade the bandwidth. The 200MHz key does everything it promises.
The rigup tool provides me with 4 keys: NSEH, NSER, NSEQ and NSFH. This document says the rigup tool should output these four keys: NSEH, NSER, NSEQ and NS8H. Is there a way to get the NS8H key?
« Reply #2 on: October 02, 2014, 11:31:15 am »
Ok, I found what I did wrong: I used rigup 0.1 instead of 0.4. With the 300MHz key from the rigup 0.4 tool I have an MSO2302A-S now.
