Author Topic: Inspection microscope with measurement capabilities  (Read 1919 times)
Offline danilsTopic starter
« on: November 30, 2022, 09:48:36 am »
Hi all,
So I bought some days ago a Dino-Lite top end USB 3.0 digital microscope with its stand and I had severe compatibility issues with Windows 11 running under parallels on a M1 Mac, in a simple word: nothing did work properly. At the end I sent this overpriced stuff back. (almost 2000 euros)
So I am asking advice for something good with measurement capability software. Budget could be around 1000 euros.
Use is PCB inspection.
Thanks!
Offline kripton2035
Re: Inspection microscope with measurement capabilities
« Reply #1 on: November 30, 2022, 10:51:47 am »
when you use usb on a mac VM, with hardware devices behind, it's far better to use vmware fusion than parallels...
I was unable to connect some usb programmers some times ago, and it worked directly wit h fusion.
just my 2 cts.
ps: on an m1 mac this could be different as fusion is not completely tested it seems
The following users thanked this post: danils
Offline timeandfrequency
« Reply #2 on: December 05, 2022, 11:50:53 am »
Hi danils,
Maybe you can check out the EAKINS IMX226 cam which embeeds a point to point distance and a circle diameter measuring feature. As a standalone device, no computer is required to use it : you just need a monitor with HDMI input and a basic USB mouse.
This newer model features a zoom control, additional measuring, recording and picture comparison tools and seems not to require any external lens.
