Author Topic: UNI-T UT61E Continuity on Car Battery and AA cell. (Moved to Beginners)  (Read 1905 times)
Offline NeelarTopic starter
  • Country: sa
This topic Moved to Beginners.
« Last Edit: December 13, 2015, 07:09:29 pm by Neelar »
Offline mzacharias
Re: UNI-T UT61E Continuity on Car Battery and AA cell.
« Reply #1 on: December 13, 2015, 06:42:27 pm »
I think this is normal operation for this meter. The battery is essentially a very low impedance.
Offline DG5SAY
« Reply #2 on: December 13, 2015, 06:59:24 pm »
Hello Everybody,
Today I got new UNI-T UT61E DMM and I tested it on my car for continuity test.
I noted that if I select continuity mode with buzzer even on all continuity modes,
and put the probes on battery 24V ( red on + ) (black on - ) or ( red on - ) (black on + ).
It makes beep and value shows zero, with this behavior I couldn't track my broken wires.
Also I tested on 1.5 AA Cell and still same result as mentioned above.
Attached snap
Please help me to solve my problem thanks.
I suggest to move this topic to the "Beginners"-Forum.  ;)
« Reply #3 on: December 13, 2015, 07:08:24 pm »
Continuity, and resistance, along with diode terst, are meant only to be used on an unpowered circuit. The ranges are not designed to be used with power present. If you are trying to measure the resistance of a battery you need to select the voltage range, and apply a known load ( a resistor or lamp) and then measure the voltage unloaded, then the voltage with a lod, and measure the current draw separately, then calculate using those values. You cannot measure them directly.
