Author Topic: Recommendation for insulation tester for automated testing line  (Read 568 times)
Offline georgdTopic starter
  • Country: cs
« on: September 04, 2024, 03:43:56 am »
I need an insulation tester that can be controlled from a computer, with 1000V test voltage. This would be part of an automated production line.
Could someone recommend such a device?
Thank you,
Georg
« Last Edit: September 04, 2024, 05:39:04 am by georgd »
Online Tjuurko
Re: Recommendation for insulation tester for automated testing line
« Reply #1 on: September 04, 2024, 06:25:06 am »
UT512 can connect to a computer.
https://eleshop.eu/uni-t-ut512-insulation-resistance-tester.html
I don't know about the possibility of control from a computer.
Offline jonpaul
    • IEEE Spectrum
« Reply #2 on: September 04, 2024, 06:29:30 am »
"insulation tester" is a wide term.
Safety?
AC/DC 1000V?
leakage current to earth?
range of current?
application eg transformer/motor insulation test?
Medical equipment compliance?
Instrument manufacture?
For old line USA firms, see Rod-L, Hipotronics, Stangenes Industries...
Jon
An Internet Dinosaur...
The following users thanked this post: georgd
  • Country: cs
« Reply #3 on: September 04, 2024, 06:46:08 am »
Here is a more detailed description of requirements:
- The factory produces mains (230/380 V) cables equipped with cable head on both side
- Instrument is intended to use in a factory line as test gear.
- Test test voltage is 1000V DC and the resistance between the cable conductors needs to be measured.
Georg
Offline jonpaul
    • IEEE Spectrum
Offline Kean
    • Kean Electronics
« Reply #5 on: September 08, 2024, 12:26:30 pm »
One of my customers uses the GW Instek GPT-9804 on the production line for their final insulation and ground bond tests.
It is controlled via LabView.
GW Instek have cheaper models in the series if you don't need all the features.
https://www.gwinstek.com/en-global/products/detail/GPT-9800
