Just saw this pop up today:
https://www.rigol.eu/products/dc-power/dp2000.htmlRigol has added a low-range current readback mode where the resolution is improved by factor 100x. Programming is still in mA level.
The programming and readback accuracies are slightly improved compared to the DP800 series. Readback is 0.15%+5mA (was 0.2%+5mA) and now also has a low-current range (up to 10mA) with 0.25%+28uA spec. The EEVblog's uCurrent does +/-0.1%+50uA in 1mV/mA range or +/-0.05%+50nA in 1mV/uA range, with a max +/-2.25A or +/-2.25mA measurement range, respectively..
I suppose it's not a bad addition, but it doesn't look like it's going to beat the uCurrent in pure accuracy. 28uA offset is still quite high if you're targeting <100uA applications. It could be OK if the offset remains reasonably consistent across output voltage changes (high CMRR), and/or it's possible to zero the instrument's offset as you may typically do before starting a low current measurement..
Other improvements are a (much) shorter processing time and dwell time.
There are also seems to be a new DP900 series, but that doesn't come with an uA current range and output/sense terminals on the back.
