Author Topic: Interpretation for a safety warning in the Rigol DP932A user manual  (Read 757 times)
Offline pstephensTopic starter
    • Twitter
Hi--I'm new to the forum and easing into electronics as a hobby.
I now have a Rigol DP932A bench power supply and it has a curious warning in the safety instructions:
Do not use this instrument to provide power for the active load.
The backflow current may cause the power control loop to be out of control,
which could further damage the devices that receives the power supply from this
instrument. Therefore, this instrument is only allowed to provide power for the
pure load that does not have the current output function.
These words do not mean much to me. What's the difference between an active load and a pure load in this context? And what is the statement warning against?
https://beyondmeasure.rigoltech.com/acton/attachment/1579/f-8bcd4294-be35-42c8-beda-dc121d720dca/1/-/-/-/-/DP900_UserGuide_en.pdf
Re: Interpretation for a safety warning in the Rigol DP932A user manual
« Reply #1 on: July 14, 2023, 03:27:10 am »
Welcome to the forum.
An active load is one that could send a voltage back into the PSU vs a resistive load
Examples are
Solenoids
Regen motors.
Back EMF/reverse voltage.
Offline Someone
    • send complaints here
« Reply #2 on: July 14, 2023, 03:43:01 am »
An alternative phrasing is that the supply is "single quadrant" and using it outside that mode can cause catastrophic damage.
https://edadocs.software.keysight.com/kkbopen/what-is-a-bipolar-four-quadrant-power-supply-583425137.html
Offline RoGeorge
« Reply #3 on: July 14, 2023, 04:59:03 am »
Also beware when charging batteries.  Always use a series diode (for DP832 it is specified in the manuals) and a fuse.
For example when charging a car battery, at a mains power surge, or at an accidental reset, or if the power supply become defective, then your battery will become the source and may damage the power supply.  And if the battery is big enough, a short circuit in the power supply can easily start a fire.
