Author Topic: Is 100Mhz enough? (calculations + charts included)  (Read 3991 times)
Offline pepelevampTopic starter
« on: January 21, 2022, 12:23:49 pm »
TLDR: Is the 100MHz fast enough for my project? Will I get sloppiness?
Hello friends.
You may know me from such threads as https://www.eevblog.com/forum/testgear/noob-scope-like-the-tds-2024b where I'm deciding on a scope. Well, I'm stuck between two scopes.
One scope is 200MHz 2ch, the other scope is 100MHz 4ch. I want the 4 channels, but I am concerned if 100MHz is enough for my project.
I'll give you the details of what I'm trying to view in the scope and the actual scope so you can see if it'll work.
I wish to sample a 20,000Hz sine wave made up of 256 segments. An 8-bit DAC, unsmoothed.
I need to see each of the 256 digital segments as clearly as I can. Eg, the more squarey the better.
20,000Hz * 256 = 5,120,000Hz.
Since I'm wanting to view square waves, I am aware that its a game of 'how many upper harmonics of my fundamental can the scope see? enough to make it squarey?'.
I am aware that 100,000,000Hz is in the neighborhood of 19x my 5.1MHz fundamental.
But I know that scopes roll off near their upper bandwidth limit and I am concerned I may be in for a shit sandwich.
Attached is a chart showing a square wave (perfect,red) at the granularity I want for my project. I basically need to see square waves that sharp in the scope. My teensy will be generating them. That part is fine.
I couldn't low-pass using desmos, but I thought I would construct the square wave out of harmonics available up to 25MHz, with the idea that near 50MHz the scope will be rolling off.
The blue line is sorta what I'd accept as passable. I just need to see it in steps, discretely. I dont want a sine. I know in real-life it wouldn't look like that - it'd be a blobby wave, but its just how I'm trying to estimate precision.
The scopes I am eyeballing are:
Siglent SDS1202X-E 200 Mhz, 2 Channels
Siglent SDS1104X-U 100 Mhz,  4 Channels.
Please excuse the crudity of the chart - I didn't have time to make it to scale or paint it.
SDS1202X-E
https://siglentna.com/product/sds1202x-e/
Key Features
* 200 MHz Bandwidth
* 1 GSa/s Real-Time Sampling Rate
* 14 MPts Waveform Memory
* 500 uV/div Sensitivity
* Maximum waveoform capture rate: 100,000 frames / second (Standard mode), 400,000 frames / sec (Sequence mode)
* Serial bus decode & trigger: standard
* Digital trigger provides low jitter
* Intensity-Graded display / Color-Temperature display mode
* Video triggering / HDTV
* Cursors * Measurement functions
* USB and LAN interfaces
* 7″ (diagonal) display
* Sequence trigger mode
* History function
* Secure erase feature
SDS1104X-U
https://siglentna.com/product/sds1104x-u/
 100 MHz bandwidth
 Real-time sampling rate up to 1 GSa/s
 Record length up to 14 Mpts
 Serial bus triggering and decoder supports protocols I2C, SPI, UART, CAN, LIN
 Advanced measurements on full memory (14 Mpts)
 Large 7-inch TFT-LCD display with 800 * 480 resolution
« Last Edit: January 21, 2022, 12:36:15 pm by pepelevamp »
Offline gf
Re: Is 100Mhz enough? (calculations + charts included)
« Reply #1 on: January 21, 2022, 01:09:54 pm »
If you want to see each step, then I would worry more about the vertical resolution, than about 100 MHz bandwidth.
What is the reason why you think that you need to see each individual step? What kind of problem are you trying to investigate?
Online bdunham7
« Reply #2 on: January 21, 2022, 01:40:41 pm »
The 8-bit DAC will give you 256 vertical levels, but what is the sample rate of the DAC?  Also what is the analog bandwidth of the output circuitry of the DAC?  You may have trouble seeing the 'squarey' signal as you might imagine it should be, but it won't be because of the bandwidth limitation of any of those scopes.
Offline gf
« Reply #3 on: January 21, 2022, 02:00:49 pm »
In the OP, the sample rate was said to be  5.12 MSa/s, and the DAC output was said to be "unsmoothed". So 100MHz is likey well sufficient. But I wonder how to resolve 256 step w/o missing codes, when the scope has only an 8-bit ADC? This could only work if the levels of the DAC and scope ADC were exactly aligned.
Offline dmulligan
« Reply #4 on: January 21, 2022, 05:22:55 pm »
If you can stretch your budget a little more there is the SDS1104X-E which can be hacked to 200MHz.
Online bdunham7
« Reply #5 on: January 21, 2022, 05:27:51 pm »
The way he arrived at the conclusion regarding sample rates is questionable because he seems to imply that this is the natural result of using an 8-bit DAC.  As for the rest, let's just say I don't expect that he is going to see what he apparently expects to see in any case.
Offline Fungus
« Reply #6 on: January 21, 2022, 06:02:15 pm »
I say "it's enough".  19x your fundamental is going to be very square, 200Mhz will make very little difference.
Offline tautech
« Reply #7 on: January 21, 2022, 07:29:34 pm »
SDS1202X-E, SDS1104X-U
https://www.trademe.co.nz/Browse/Listing.aspx?id=3439619695
https://www.trademe.co.nz/Browse/Listing.aspx?id=3439619698
Yes those are the only 2 models we list on Trademe and at prices somewhat above what we can supply direct due to their exorbitant sales success fees.  :horse:
We have 4ch X-E and X+ DSO's too.
Drop by and try before you buy.
« Last Edit: January 21, 2022, 07:53:17 pm by tautech »
Avid Rabid Hobbyist
Offline kcbrown
« Reply #8 on: January 21, 2022, 08:28:29 pm »
Hello friends.
What you're presuming is that the Teensy's slew rate is high enough to produce square wave harmonics that would exceed the 100 MHz scope's ability to show them.   That is highly questionable, at the very least.  At most it will depend on which Teensy you have.
For the Teensy 3.2, which uses a Freescale MK20DX256VLH7, the slew rate is mentioned directly in the datasheet: at most 1.7V/us in high power mode.  This is as fast as it gets for that part, and for a 3.3 V P-P signal would result in at most a (roughly) 250 kHz signal.  The -3dB bandwidth of the DAC is 550 kHz at most, per the datasheet.
The Teensy 2.0 uses an Atmel ATMEGA32U4 microcontroller.  The datasheet doesn't specify slew rates or DAC bandwidths, but seeing how the speed of the MK20DX256VLH7 is at least an order of magnitude higher, it's highly unlikely that the ATMEGA32U4's DAC's performance will be any better, and it's likely worse.
The Teensy 4.0 (and 4.1) uses an NXP MIMXRT1062-DVL6A, which is another order of magnitude faster than the MK20DX256VLH7.  Its datasheet doesn't specify the slew rate or bandwidth of its DAC, so I can't say what to expect with it, but even if we assume an order of magnitude improvement in the slew rate, that's still easily within the 100 MHz scope's ability to see the edge clearly.
Put another way, the bandwidth of the output of your Teensy is almost certainly easily within the 100 MHz scope's ability to faithfully show anything you generate with it.
« Last Edit: January 21, 2022, 10:08:11 pm by kcbrown »
Offline Fungus
« Reply #9 on: January 21, 2022, 08:55:20 pm »
The Teensy 2.0 uses an Atmel ATMEGA32U4 microcontroller.  The datasheet doesn't specify slew rates or ADC bandwidths, but seeing how the speed of the MK20DX256VLH7 is at least an order of magnitude higher, it's highly unlikely that the ATMEGA32U4's ADC's performance will be any better, and it's likely worse.
The ADC in those ATMegas (ie. Arduinos) can only handle about 10kHz.  :)
You can clock the ADC higher but there's no point, the internal sample-and-hold capacitor won't charge any faster, all you'll get is a low-pass filtered version of the signal.
If you switch between channels the capacitor won't fully charge and you'll get crosstalk between channels.
Offline NaxFM
« Reply #10 on: January 21, 2022, 09:02:12 pm »
To me the 1104-U is really not worth the money.
The 1104-E, for 100 bucks more gives you much, MUCH more.
Easily hackable for 200MHz bandwidth, dual ADC (double the sampling frequency), mixed signal capabilities and usable with arbitrary function generation. The 200MHz bandwidth alone is worth the money.
If you're on a budget, just wait and collect those 100 bucks before buying the 1104-U, IMHO
Now, regerding seeing the steps. It's a bit hard with an 8 bit oscilloscope, you can but as PeDre demonstrated you have to apply a massive vertical zoom to see anything.
If I absolutely had to see the steps as clear as possible and have no budget limit, I'd go for the siglent SDS 2104 which has a 10 bits ADC up to 100 MHz, but that's well over 1000bucks... (Hackable to 500MHz tho, well worth the money)
Offline kcbrown
« Reply #11 on: January 21, 2022, 10:06:24 pm »
Sigh.  I typed "ADC" when I meant "DAC" (I've since corrected this).  But what I was looking up was the DAC specs.
Anyway, yeah, I'd expect the DAC performance in the ATmega to be around the 10 kHz range.
Offline kcbrown
« Reply #12 on: January 21, 2022, 10:15:51 pm »
The 1104X-E (and, I presume, the 1104X-U) has an "eres" acquisition mode where you can increase the effective resolution through oversampling.
Offline nctnico
« Reply #13 on: January 21, 2022, 10:24:41 pm »
No, it has an 8 bit ADC. There is a 10 bit mode, but that is still coming from an 8 bit ADC. If you want true 10 bit (or more), then you'll need to look somewhere else (R&S RTB2004 for example).
Then again, the OPs project goals make next to no sense at all so there is little use in suggesting anything. An oscilloscope is not a high precision instrument for measuring amplitudes anyway. If the OP wants to measure DAC steps accurately, then he/she needs to set the DAC to a specific output code (DC level) and use a >4.5 digit DMM to measure the DAC's output value.
« Last Edit: January 21, 2022, 10:27:25 pm by nctnico »
« Reply #14 on: January 22, 2022, 06:48:00 am »
Hello friends. I'm absolutely staggered at the effort you've gone to with your replies. While I read through things here (which will take some time), I'll answer some questions about the project.
TLDR: I need to discretely and explicitly control the phase & timing of two channels. One analog, one digital. It sounds all ass about face, but I gotta do it this way for 'reasons'.
Voltage range & voltage-step-size isn't too much of an issue. I know the linearity of the 'DAC' and I'm more concerned about the timing - the stops/starts of these steps. I know they're in time - I just want a scope that will let me see it without too much smoothing of my edges.
The 'DAC' and microcontroller generating this is a solved problem: I'm using parallel-IO into a resistor-ladder. This is all working just fine on my 84MHz SAM3X8E (Arduino due).
My objective is to have two channels tightly in sync, one is a sine wave, and the other is digital logic. This is easy since I can push 32 bits in parallel. I'm using about 9 i/o pins at the moment. 8 of them go to the "DAC".
This is all just fine, as measured by the Tektronix TDS 2024B scope (200mhz) that I've borrowed. It all works perfectly fine. Problem is, I've returned the scope.
I'm just upgrading to the Teensy 4.0 (600MHz) because I need to do more floating-point math and conditionals inside my 5.1MHz interrupt routine than the SAM3X8E can handle. I know about not doing stuff inside ISRs - its necessary here but it'd take too long to explain why.
I assume the slew rate of the Teensy blows the Arduino Due out of the water & will also be of no concern.
This will all eventually get pushed out to some amplification, which may low pass things, but at that stage of the pipeline I'm fine with the smoothing. I'll filter off the sine wave at something phase-friendly. I just need explicit control over every step of that wave form before its smoothed into the sewer.
Thank you all for your huge replies - I'm going to fully read through them now. You guys are heroes.
« Reply #15 on: January 22, 2022, 07:33:54 am »
I'm trying to have digital logic signals go high/low at the exact time of my choosing relative to the 256-step sine-wave. Ive slowed everything down & checked the vertical resolution & my generator is a-okay. I need to see every individual voltage step so I can be certain of the timing between my digital logic & steppy sine wave.
My question is ultimately - is the 100MHz scope fast enough to let me still see my signals before its own bandwidth limitation starts rounding everything off?
In the future it may not be a simple sine wave :) Its software generated.
« Reply #16 on: January 22, 2022, 07:35:18 am »
Its all good mate, I made the DAC out of resistors. I've had it working already. I'm just giving back the scope I'd borrowed, and and I'm uncertain if the scope I wish to buy will be able to see the signals I'm making.
Offline Fungus
« Reply #17 on: January 22, 2022, 08:11:59 am »
They don't have a DAC.  :)
« Reply #18 on: January 22, 2022, 08:12:56 am »
OooOooo. So the U is the wimpy version of the E, but kinda 'pretend' wimpy where its downgraded in the firmware aye. This is a rabbit hole worth looking into.
« Reply #19 on: January 22, 2022, 08:20:39 am »
This is very good information. I hadn't noticed that the 'E' version of the 1104 was available. You're right - its a much smarter option. You may have actually touched the magic spot & convinced me. I'm going to pursue down this rabbit hole.
Damn. Yeah this would be where I'd go if my needs were simply multiplied up to 2x and I could spend 2x the money. Thanks mate, this helps because it sorta gives me an upper-bound & calibrates my expectations of features<>costs.
« Reply #20 on: January 22, 2022, 08:42:56 am »
Saying project goals make no sense when the project goals weren't specified -that's a paddlin.
Saying theres no use in suggesting anything when the performance metric was specified - that's a paddlin.
Giving a course of action based on the absence of information, and when by your own admission you don't know of a project goal- that's a paddlin.
The world will be a better place without people such as yourself who lean into providing 'advice' yet belittle projects at the same time - all before you even understand what is happening.
Nobody needs that bullshit, and I won't tolerate it.
I'm after help about scope roll-off & bung frequency response and others here have been very helpful.
« Reply #21 on: January 22, 2022, 08:54:01 am »
Thanks mate this is great advice. I appreciate your help going into detail with the slew rate.  Yup I got the Teensy 4.0. I'm really going hardout on the CPU.
I'm using parallel-IO into a resistor ladder instead of using the built-in DACs because its been too hard to sync the DAC to digital IO.
Its way, way, waaaaaaaaaaay faster - at least on my SAM3XE on my Arduino DUE. Waaaaaaaaaaaaay faster.
Slew rate on the DAC had indeed  been a problem - trying to sync things up when the slew rate is all sloppy woppy.
Thats why I'm using a resistor-ladder from parallel-IO. Super duper fast. Later on I'll be amping things up & bandwidth-limiting etc - but by that stage I know everything's in sync etc.
« Reply #22 on: January 22, 2022, 09:06:07 am »
I have recreated the question out of interest with the DS1104Z (8-bit, 100 MHz) and RTB2000 (10-bit, 300 MHz), perhaps the screenshots will be helpful.
The arbitrary signal comes from the Rigol DG4162, and is terminated with 50 ohms at the oscilloscope. The 2 Vpp, 20 kHz sine consists of 256 parts in the vertical.
Peter
Dude this is extreme. You really went to town for me here. Thank you heaps.
Its quite clear on the 100mhz 8-bit guy that when zoomed out the top of the wave gets pretty hairy. But zooming in lets you see the voltage steps quite well, even if those straight lines have a 5 o'clock shadow.
I really appreciate you going to the effort of creating these charts. As one might expect the global amplitude of the 256-step sine wave does affect the temporal precision because it requires a faster slew rate to accomplish. It does look like 100MHz will be enough to capture what I want to see.
I guess the next question is the other specs - the maximum precision that the scope can see. Mind you, for 2v peak to peak divided by 255 is 7.5mV. This scope I'm eyeballing can see 0.5mV. So I'm in good company. Thank you mate.
« Reply #23 on: January 22, 2022, 09:11:39 am »
Where we're going - we don't need DACs.
Offline tautech
« Reply #24 on: January 22, 2022, 09:35:28 am »
Peter
Yes, as expected when looking closely at a 14 bit AWG waveform, nothing too special in that.
Avid Rabid Hobbyist
Offline tautech
« Reply #25 on: January 22, 2022, 09:43:17 am »
No the X-U is a different design with a quite different features set.
X-E uses 2 ADC's whereas X-U only one therefore X-U sampling rate is only sufficient to 100 MHz with all channels active.
Attached is a comparison chart.
« Last Edit: January 22, 2022, 10:35:18 am by tautech »
Avid Rabid Hobbyist
Offline NaxFM
« Reply #26 on: January 22, 2022, 10:31:07 am »
Unfortunately not, It's really a different design with more limited front end, single ADC and no circuitry for mixed signal, maybe even the FFT is more limited, but i'm not sure about that.
With 100 bucks more you get a 200MHz scope with dual ADC , to me is a no brainer, the 1104-U shouldn't even exist in my opinion. If I was (and I am) on a tight budget i'd simply wait to collect more money to buy the 1104-E instead of bying the 1104-U right away
Offline Fungus
« Reply #27 on: January 22, 2022, 10:38:07 am »
Yep. The E version is crippled. The 2 channel Siglents are also missing a lot of features.
The two 'scopes worth considering in this price range are: Rigol DS1054Z and Siglent SDS1104X-E.
The Siglent is 'better', yes, but it costs about 45% more so it ought to be. The Rigol is a perfectly good 'scope though.
Decide on your budget then the choice is made for you.
Offline tautech
« Reply #28 on: January 22, 2022, 10:51:47 am »
Not so SDS2202X-E which has a very similar feature set to the 4ch X-E's.
Avid Rabid Hobbyist
Offline Fungus
« Reply #29 on: January 22, 2022, 10:57:42 am »
Siglent's naming department rocks!
Offline tautech
« Reply #30 on: January 22, 2022, 11:30:29 am »
Simple isn't it.
2= 2 GSa/s, 20= 200 MHz, 2= 2ch, X-E models have similar but slightly different feature sets.
Avid Rabid Hobbyist
Offline NaxFM
« Reply #31 on: January 22, 2022, 11:45:14 am »
Simple isn't it.
Never occurred to me that the first number was the maximum sampling rate, everything is clearer now!
« Reply #32 on: January 22, 2022, 12:40:17 pm »
OH mate, thats a great looking Rigol. Got me thinking now - would 50MHz be enough for my project? It might be actually. Damn, why do I have to be nerding with such fast signals. I can offer a reason as to why these Siglents were on my to-buy list - its because they're passively cooled with no fans. I have hyperacusis. The pain threshold for my hearing is too low. Eeeeeeverything irritates the crap out of me.
« Reply #33 on: January 22, 2022, 12:41:46 pm »
Thank you Tautech - your chart is super helpful. Its a pretty obvious choice to get the E series aye. I just need to confirm if this scope indeed is passively cooled.
Offline Fungus
« Reply #34 on: January 22, 2022, 12:44:51 pm »
You can EASILY unlock the Rigol DS1054Z to 100MHz.
Enter your serial number on this page and it generates a key for you: http://gotroot.ca/rigol/riglol/
The only key you need these days is DSEA, everything else comes as standard. You can also remove the unlock just as easily and go back to 50Mhz if you ever need to.
Fanless Siglents? Where did you get that from?  :-//  Quieter fan swaps are common in both Rigols and Siglents.
« Last Edit: January 22, 2022, 02:42:35 pm by Fungus »
Offline nctnico
« Reply #35 on: January 22, 2022, 01:21:21 pm »
Well, In have been designing circuits professionally for decades and have used & owned more different oscilloscopes (from low end to very high end) compared to the average forum member. And yet up to my post the details you posted prevented me from making a useful suggestion to you. I prefer to stay on the safe side. Judging from how you are still jumping between various models based on the latest suggestions, I strongly suggest you make a list with pros and cons for various models and make a decission based on that. Try to make a comparison between the Tektronix TDS 2024B you have used before; what did you like and what didn't you like about it. Shared and individual channel controls can make a difference but the lower cost models suggested so far have shared controls where the TDS 2024B has individual channel controls. In the low cost segment GW Instek is one of the few brands that have individual channel controls (GDS-1054B is a very cheap 4 channel model with individual channel controls).
However, none of the models suggested so far is fanless. A requirement which should have been in your first post. Many people are replacing the fans in their oscilloscopes with lower noise models for better comfort (but likely voiding warranty). Rohde & Schwarz made fanless DSOs up to recently; look for HMO1000 series (for example: https://www.batronix.com/shop/rohde-schwarz/HMO1000.html). These likely can be found on the second hand market and at equipment dealers.
« Last Edit: January 22, 2022, 01:47:10 pm by nctnico »
« Reply #36 on: January 22, 2022, 01:53:58 pm »
I don't care about how good you are at scopes with an attitude like yours. I don't need someone telling me to write down what I like & dislike about scopes & telling me how to make decisions. I have select posts for specific criteria. Just get lost - you aren't helpful.
« Reply #37 on: January 22, 2022, 02:01:40 pm »
Enter your serial number on this page and generates a key for you: http://gotroot.ca/rigol/riglol/
Yeah mate - I had these written down as fanless for someeee reason.  Mind you look at the fan in these guys.  Tiny wee things. Must sound like an RC car whizzing around.
Thank you for the link - thats very helpful. Its just the processor that gets cool aye? And the FPGA? Digital stuff. I had horrors about me changing the fan & upsetting some carefully balanced caps or something & having bung measurements forever.
EDIT: Watching the eevblog teardown - that aint no buzzy fan. 18dBA. Smells good to me.
« Last Edit: January 22, 2022, 02:35:53 pm by pepelevamp »
Offline Fungus
« Reply #38 on: January 22, 2022, 02:30:13 pm »
Nah, it's easy. Just a standard fan connector like in a PC. Ten minutes work with a screwdriver to take the back off and swap it.
Edit: I used this one in my Rigol and the difference was massive. I wish I'd done it on the first day I got the 'scope.
https://www.eevblog.com/forum/testgear/rigol-ds1054z-ds1000z-fan-noise/msg1228358/#msg1228358
« Last Edit: January 22, 2022, 02:43:48 pm by Fungus »
Offline tautech
« Reply #39 on: January 22, 2022, 09:00:45 pm »
None we stock from Siglent are without fans. If you want the horsepower you have to cool the engine.  ;)
The quietest we stock is the 2ch SDS1202X-E which is running a single ADC.
Pop out to see us with no commitment to buy and judge the fan noise for yourself.
Avid Rabid Hobbyist
Offline kcbrown
« Reply #40 on: January 23, 2022, 11:51:46 pm »
Well, in that case, then the effective slew rate is going to be the result of a combination of the slew rate of your parallel I/O pins and the RC time constant of your resistor ladder.  This is where you get into some tradeoffs.  You can use lower value resistors in your ladder, but if you do so then your parallel lines will have to source more current, and there will be limits to that (not to mention that the load impedance might well affect the slew rate of the output pins).
Because you're moving to a Teensy 4.0, but your experience is with the Arduino Due, you may need to perform some experiments to see whether your approach is really worth going with, as opposed to using the internal DAC.
In any case, most microcontrollers I'm aware of don't even come close to the limits of a 100 MHz scope when it comes to seeing the timing of the signal edges on the I/O pins.  This really shouldn't be much of a surprise.  Extremely fast edges on the outputs start to demand a lot more work on the board layout and the load in order to avoid ringing.  In essence, you start to come up against transmission line considerations if you attempt to drive the output too hard, and most microcontroller boards like the Teensy are oriented towards hobbyists using breadboards and other inexpensive prototyping mechanisms wherein things like transmission line impedance matching aren't being considered.
So the bottom line here is that I think you'll be quite well off with even an entry level 100 MHz scope for this.
At this point, I think it's going to be worth asking what your expected future use cases will be and what your budget is.  Different scopes have different things that they're particularly good at, so it would be helpful to have a better idea of the overall use case set so that scopes that have those as their strengths can be pointed out.
Online EEVblog
« Reply #41 on: January 24, 2022, 01:21:04 am »
If someones response on the forum isn't helpful then why not just ignore it?
Online EEVblog
« Reply #42 on: January 24, 2022, 01:24:17 am »
Maybe what you want here is the ability to turn of SinX/x interpolation so you can see just the samples instead of a smooth "interpretation" of what's happening between the samples. 100MHz analog bandwith should be enough here I'd imagine.
EDIT: Just noticed you said 20KHz. In that case this isn't relevant. Any scope will show what you want, and you can overrange the vertical to help see details if needed.
« Last Edit: January 24, 2022, 01:28:49 am by EEVblog »
« Reply #43 on: January 25, 2022, 06:29:26 am »
because bullshitters like that make life awful for newcomers for no good reason. and nobody likes the wankery. just too old for that shit, danny glover, etc.
but anyway, I think you're right re 100mhz being enough. I know my 'dac's amplitudes / codes are cool already so thats fine. I was concerned that 100mhz may be just low enough to shave off the edges of the square wave transitions & stop me being assured of my timing. yeah its a 5.1MHz square wave, but those transitions, right.
i have similar issues with the amplifier stage at the end of my signal chain - but its a lot easier figuring out which opamp to buy than a scope.
