I am embarrassed to say that I accidentally sent RF into the signal generator at about 50 watts. This is higher than the overload circuit can protect, I think.
The resistance across the output N-connector is zero or open. It should be 50 Ohms, right (with power off)?
The signal generator still has a normal output as far as I can tell.
Does anyone know how to check this out and repair it?
I am looking through the service manual.
Richard
