Author Topic: Rigol MSO5000 Display Readability Suggestions  (Read 6202 times)
Offline Fungus
Re: Rigol MSO5000 Display Readability Suggestions
« Reply #25 on: April 19, 2019, 12:59:09 pm »
Maybe the problem is the touchpanel.
Maybe.
Offline iMo
  • Country: pm
« Reply #26 on: April 19, 2019, 02:28:11 pm »
Simply use the tool as-is. Face it from front. The more you will elaborate with the brightness "issue" the worse for your mindset. It is a cool oscope..  :-+
I got to the very edge of the abyss, but since then I have already taken a step forward..
Online Martin72
  • Testfield Technician
« Reply #27 on: April 19, 2019, 08:18:10 pm »
Sure it is and for me the display thing isn´t such a big issue as other people claiming (without having a mso5000...) - nevertheless a little "tuning" makes fun or only the thinking about it.
By the way, really annoying is the fan....really annoying.
Online ebastler
« Reply #28 on: April 19, 2019, 08:55:44 pm »
Several Pictures taken just a few minutes ago:
Yes, looks like there is a lot of scatter of the room light from the screen's surface, presumably the touch panel. That seems to cause both, the perception of a dim display (relative to the scattered background) and low contrast.
I don't think putting a better LCD behind the same touch panel would result in much improvement.
Online Martin72
« Reply #29 on: April 19, 2019, 09:08:25 pm »
With a closer look, you can see the rows/columns of the touchpanel.
You might be right, here´s a pic in the late afternoon, daylight was already gone:
Online ebastler
« Reply #30 on: April 19, 2019, 09:17:12 pm »
Ahh, that's much better! And it confirms that it's mainly backscattered light from the room which messes with the contrast.
I see a marketing opportunity for a new accessory:
A nice screen bezel or hood. Also helps with the vintage look!  8)
Online Martin72
« Reply #31 on: April 19, 2019, 09:23:16 pm »
 ;D
Or adaptor for polaroid cams…..
We still got one !
Offline maginnovision
« Reply #32 on: April 19, 2019, 09:24:16 pm »
Go figure, no light and now it looks better. It's not relevant because you shouldn't be working in the dark though.
Online Martin72
« Reply #33 on: April 19, 2019, 09:30:50 pm »
I´m working 24/7.... 8)
Joking, it wasn´t so dark as the picture might look alike.
Under working conditions ( at company with excellent light conditions) you must stare directly to the screen - thank god, my desk have a second level in eye-height...
« Reply #34 on: April 19, 2019, 09:45:03 pm »
I actually do work at night but it's never dark. That's actually a case for a glossy screen though. So R&S needs matte screen protector and the Rigol needs a glossy glass screen protector. That display is pretty dim from everything I've seen. Even in your dark picture the grid lines disappear off center. It really is a big disappointment for otherwise decent hardware. I guess you say it's also got the typical Rigol fan but that's never bothered me much. A Datron 4000 fan on the other hand... :scared:
Online Martin72
« Reply #35 on: April 19, 2019, 09:58:44 pm »
The fan of the LeCroy WaveJet beats all....40mm diameter and loud as hell  ::)
Offline typoknig
« Reply #36 on: April 22, 2019, 02:25:00 pm »
What modifications were done before these pictures were taken?
Online Martin72
« Reply #37 on: April 22, 2019, 03:25:52 pm »
None, it´s untouched.
