Author Topic: Is it possible to use Riglol to unlockDP831 PSU  (Read 3229 times)
Offline 2N3055Topic starter
  • Country: hr
« on: July 01, 2016, 04:12:55 pm »
Hello !
I searched for quite a while and couldn't find any information whether Rigol DP831 can be unlocked with riglol same as DP832...
They share the same firmware and all...
Thanks for the answers !!
P.S. I'm new to the EEVblog so please be patient till I learn the ropes...  :phew:
Dr. Richard W. Hamming
Offline TurboTom
Re: Is it possible to use Riglol to unlockDP831 PSU
« Reply #1 on: July 01, 2016, 11:15:04 pm »
At least DP811 works. I guess that's true for all the DP800 series.
Cheers,
Tom
  • Country: hr
« Reply #2 on: July 02, 2016, 07:54:02 pm »
Thanks a lot Tom!!
If I find out for sure I will post the info...
Take care!!
Sinisa
Offline smile
« Reply #3 on: December 29, 2016, 06:54:13 pm »
Thanks a lot Tom!!
Take care!!
Sinisa
Well did i work on DP831?
  • Country: hr
« Reply #4 on: December 29, 2016, 07:40:28 pm »
Sorry for that, I forgot to post..
Yes, it worked flawlessly.. Also, I would recommend to put keys on a USB stick ( there is Rigol document explaining it), and just load them.. It is much easier than entering them trough DP UI...
Have a good one!!
Offline radef
« Reply #5 on: January 18, 2023, 06:06:42 pm »
So you were able to turn a DP831 into a DP831A, correct?  (or into 832?)
Offline thm_w
  • Non-expert
« Reply #6 on: January 19, 2023, 12:22:35 am »
Yes 831A.
We have many threads: https://www.eevblog.com/forum/testgear/need-help-hacking-dp832-for-multicolour-option/425/ Use the print button and search for DP831.
The following users thanked this post: radef
Offline radef
« Reply #7 on: January 19, 2023, 05:18:45 pm »
Thanks for confirming.
And many thanks for the pro-tip: print button then search  That's excellent!
