Products => Test Equipment => Topic started by: tecnicaemail on September 17, 2020, 03:38:52 pm
Title: Is it worth exchanging Multimeter UNIT U61E for U532?
Post by: tecnicaemail on September 17, 2020, 03:38:52 pm
Dear friend wanted opinion from you, is it worth the exchange?
I own the UNIT UT61E and the exchange for a UT532 appeared.
From what I saw on the Site at UNIT the U532 was discontinued, I didn't find anything about him, visibly at hand he is a Multimeter, but I'm not an expert and I wanted the opinion of friends.
Thanks in advance.
Title: Re: Is it worth exchanging Multimeter UNIT U61E for U532?
Post by: 2N3055 on September 17, 2020, 04:45:16 pm
https://eleshop.eu/uni-t-ut532-insulation-resistance-tester.html
some info
Post by: tecnicaemail on September 17, 2020, 04:59:51 pm
some info
In your opinion which should I stay?
Post by: 2N3055 on September 17, 2020, 05:22:04 pm
I don't know what you are going to use it for.
UT532 has up to 1000V insulation resistance measurement. That is good for checking insulation in transformers, motors etc.
UT61E is more of a electronics meter with some other measurements. And PC link.
Compare functions and decide what will be most useful to you.
Post by: tecnicaemail on September 17, 2020, 06:18:49 pm
I will use it for electronics, laptop repairs, etc. But I want a good instrument and if the UT532 is better then I take it, I’m in doubt, I really liked the 532 because it has internal light that we can turn on and off whenever you want, the bug is huge and robust and very good, the only thing I didn’t like about the 532 and it doesn’t have amperage measurement and if my memory serves me correctly, its capacitance is less than that of the 61e?
There I am in this doubt because the multimeter will be used for these purposes and voltage measurements to standard residences.
Post by: 2N3055 on September 17, 2020, 06:37:51 pm
Keep UT61 then. Quality wise, they are both same UNI-T quality, not crap but not top notch either. They do the job, but not very robust.
Post by: Fungus on September 18, 2020, 07:14:29 am
No.
