Author Topic: Is my Siglent 1032 Defective???  (Read 546 times)
Offline watchmakerTopic starter
  • Self Study in EE
    • Precision Timepiece Restoration and Service
« on: October 27, 2024, 09:52:39 pm »
I wasted today trying to align an FM radio.  But my sweeps made no sense.
Finally, I decided to check the output of the Siglent against my TinySA.
Below are pics of the setup and the screenshots of when I trigger off the Siglent and then the TinySA.  I also took pics of the TinySA setting and the Siglent setting.  The Setup shows before I set both to 20ms sweep time.
The trace of the TIny SA breathes as expected.  The trace produced by the Siglent is hash with no evidence of "breathing".
Before I call Siglent, I would like to ensuure It is not me being me.  Output 1 and Output 2 produce the same result.  While I was trying to use  10.7MHz, you can see these sweeps are set for 100KHz.
I corrected the setup picture.
THANKS!!
« Last Edit: October 27, 2024, 10:11:18 pm by watchmaker »
Regards,
Dewey
Re: Is my Siglent 1032 Defective???
« Reply #1 on: October 27, 2024, 10:08:01 pm »
Use a Burst setting also for the sweep.
  • Self Study in EE
« Reply #2 on: October 27, 2024, 11:07:40 pm »
Thanks Tautech.  I will do this in the AM; after I clean up the barf.  I was elbow deep in leads and stuff by the time I wrote my plea.  Called it a night.
Regards,
Dewey
Regards,
Dewey
  • Self Study in EE
« Reply #3 on: October 28, 2024, 01:42:38 am »
I think I understand why you wanted me to test Burst Mode.  The trace of N cycles jumps right to left.  The trace is clear at 10KHz and 10MHz, but it will not lock.  I can tell myself this is very similar to what I see in the Sweep function.
Regards,
Dewey (Could not let it rest)
Regards,
Dewey
« Reply #4 on: October 28, 2024, 06:53:04 am »
I believe you have some settings incorrect......I look at your screenshots and everything is AC coupled, why ?
I haven't got a SDG1032X to test so used my SDG6022X that has the same functionality albeit to much higher frequencies.
Sweep 10-100 kHz over a set duration.
The following users thanked this post: Performa01, watchmaker
  • Self Study in EE
« Reply #5 on: October 28, 2024, 12:24:29 pm »
Because I am being me???  Thank you!  Cleaned up my work area so I can see what I am doing and set trigger to DC.  Sweep now takes a deep breath.
Warmest,
Dewey
Regards,
Dewey
