Author Topic: Is the Rigol MSO1074Z hackable?  (Read 15709 times)
Offline mikehs
Re: Is the Rigol MSO1074Z hackable?
« Reply #25 on: January 27, 2017, 12:03:01 am »
Thank you for the help, it worked!
All newbies like me, you must delete all the characters in the SN entry box before entering your SN. I deleted up to the 'D', but that apparently does not work.
Offline typoknig
« Reply #26 on: April 07, 2019, 05:19:42 am »
As it currently stands, you will need an appropriate JTAG debugger.
Smgvbest has an excellent how-to here https://www.eevblog.com/forum/testgear/sniffing-the-rigol's-internal-i2c-bus/msg569236/#msg569236 , far better than my attempt a few posts earlier which had been written some weeks after doing it (for reference here https://www.eevblog.com/forum/testgear/sniffing-the-rigol's-internal-i2c-bus/msg566312/#msg566312 )
Smgvbest says that the debugger she used is no longer made. I used an Olimex ARM-USB-OCD-H which is still available.
Looks like the link you posted isn't quite right any more.  The apostrophe in "rigol's" breaks things.  Here is the correct link:
https://www.eevblog.com/forum/testgear/sniffing-the-rigol_s-internal-i2c-bus/msg569236/#msg569236
The following users thanked this post: Fungus
