Author Topic: Is the SDS2000X HD worth the upgrade from the SDS2000X Plus or Rigol DHO1000?  (Read 5479 times)
Offline antianTopic starter
Hi, I'm looking to get a new upgraded scope for my work that only works with analog signals and ideally I need a minimum of 200 MHz BW with 500MS/s on all 4 channels. I have a budget of ~$2000 USD but if I wait a bit I can probably go up to ~3000 in a month or two or I can ask for more funding from another source. I've traditionally used Siglent or Tektronix scopes and used the high-definition acquisition modes for effective 12-bit but now a hardware 12-bit sounds very attractive and the price of the Rigol DH1000 hacked at $599 (currently on sale) sounds almost too good to not try. The SDS2104X Plus based for $1399 can be hacked it seems to the 350 MHz and that can operate at 10 bits, although the BW drops too 100 MHz which isn't ideal but I might be okay with 350 MHz with traditional high resolution mode. Does anyone have any recommendations on if the upgrade to the SDS2000X HD would be worth it from either scopes? And if between the two, is the SDS2000X plus worth basically two Rigol DHC1000? I am a little hesitant on the Rigol scopes because I have seen some people reporting more issues and more noise.
Offline tautech
Welcome to the forum.
FYI
SDS2000X Plus and SDS2000X HD are both 500 MHz designs and each run two 2 GSa/s ADC's allowing for 350 MHz operation on all 4 channels while retaining 1 GSa/s sampling on each channel.
However to operate with all 4 channels active BW is auto-reduced to 350 MHz to meet Nyquist whereas when only 2 channels are used/active and one assigned to each 2 GSa/s ADC, their full 500 MHz BW is maintained.
The HD model is a professional product with very low fan noise for this class of instrument.
The following users thanked this post: antian
Hi thank you, is the fan that big of an issue? I'm guessing that it could be swapped out for something if alot of people complain about that. I think I'm wondering if the 12 bit will be worth the cost upgrade since I believe if you use the SDS2000X plus in the 10 bit mode it reduces the BW to ~ 100MHz according to the data sheet so the SDS2000 plus even if it could be hacked will not be able to operate at 200 MHz with the 10 bits, unless I am mistaken. It seems the SDS2000X HD is the lowest entry from siglent for 12bit with at least 200 MHz BW, until the SDS1000X HD is released.
Offline tautech
The 2kX HD has a properly controlled fan whereas 2kX Plus does not.
They both use 80mm fans.
Quite correct, all SDS2000X Plus models are 100 MHz BW limited when 10 bit mode is engaged.
At this time, correct.
SDS1000X HD has a single 12 bit 2 GSa/s ADC, shared by all channels as is the sample memory whereas units that run dual ADC's also have dual memory packages so memory is just halved and not quartered like scopes with a single ADC/ASIC.
My 200 MHz prerelease unit limits BW to 100 MHz with all channels active.
SDS2000X HD models have recently dropped in price and are currently offered with a promotional options bundle for a nice additional saving.
If you can stretch to the 2kX HD and add the option bundle I'm quite sure you wouldn't regret it.
Offline Martin72
  • Testfield Technician
No, 92mm...Both.  ;)
And yes, the HD is quiet, nearly dead. :D
Offline rf-loop
  • Country: cn
No, 92mm...Both.  ;)
It is specified for environmental temperature range 0 - 50 °C
Put it to 50 °C room...or a test cabinet modeling environmental substances...    is it still silent. ;)
But yes, on my table, normal around 22°C room temp... barely audible when you listen really closely and when other devices are turned off. Does not include the start-up phase when the fan runs at high power.
« Last Edit: December 04, 2023, 09:11:27 am by rf-loop »
EV of course. Cars with smoke exhaust pipes - go to museum.
Online tszaboo
I don't think you can buy the upgrades to the SDS2000X HD with 100% discount. Something to keep in mind.
right I looked and it seems like there isn't any hack for the SDS2000X HD currently, is that correct?
Online pope
 ;D
Offline tautech
right I looked and it seems like there isn't any public hack for the SDS2000X HD currently, is that correct?
FTFY  ;)
:o I'll keep that in mind. Do you think the SDS2000X is worth the upgrade from the Rigol DHO1000 that can be hacked to the DHO1204? It seems some people have some issues with it but its at a lower price point
Offline tautech
Of course it's cheaper, the rigol is not a 500 MHz design !
Time you spent some study on datasheets.
Don't forget some study of the acquisition systems mentioned in replies 1 and 3.
Sorry I meant to clarify that the comparison would be at the same BW of 200 MHz so SDS2204X HD vs DHO1204. For my work I work in only analog resolving random voltage peaks that can be sensitive to noise so I'd typically use at least 200+ MHz but I have a tektronix for the higher BW. The SDS2204X HD at $3200 is assuming it is not hacked and the DHO1204 is $1099 at current sale price or DHO1074 hacked at only $599. The DHO1204 can do the 200 BW at 500 MS/s on 4 channels and the SDS2204X HD can do 1GS/s.  The 500 MS/s is probably sufficient for the 2x the BW requirement. It's basically a $2k difference between the DHO1204 and SDS2204X HD.
The following users thanked this post: Ogim
Online KungFuJosh
  • TEAS is real.
Those 2 scopes are in different worlds. Yes, the SDS2204X HD is absolutely a better scope. Do you benefit from that or not? You have to study the datasheets and see what features you might actually need. The DHO is an entry level scope, and the SDS is a pro level scope. Both cars have 4 tires, which one is right for you is the question.
Offline Martin72
And "scopes" from Fnirsi are even much cheaper than the both mentioned, everything is relative. ;)
I switched from an SDS2000Xplus to a 2000X HD last year.
I was a little disillusioned at first, as the advantages were not immediately apparent to me.
That has now changed dramatically. ;)
Online ebastler
As others have said, the higher price buys you a much better scope. But given the requirements you have described, and the massive price difference, I would tend to say: If all you need is 200 MHz bandwidth, no logic analyser, no Bode plots -- get the DHO1074, hack it to 200 MHz and try it out.
If it turns out to meet your needs, you have saved yourself $2600. If it does not, replace it with an SDS2204X HD, and either sell the DHO or keep it as a third scope -- its price is almost insignificant in comparison. ;)
Offline thm_w
  • Non-expert
I would agree for hobby on a budget get the DHO, but this is a work purchase, OP saves no money either way. Use the max budget for work.
Offline hansibull
  • Country: no
Depends on where you buy the upgrades from  ;D
I have an SDS2000X HD on a VESA PC monitor arm at my desk, and It's hands down the best scope I've used. I've had an R&S RTB2004 at my desk for the last four years, and the plan for the SDS2000X HD was to use it as a second scope at the lab, while still using the RTB2004 as my everyday scope. But after getting familiar with the SDS2000X HD, I had to admit that I liked this one even better. And that says a lot because the RTB2004 is a very refined instrument; much better than any Rigol I've used.
The fan is very silent, and the scope can be remotely controlled using SCPI commands, the self-hosted web interface, or using VNC. Very convenient if you quickly want to grab a screenshot. The only complaint I have compared to the RTB2004 is the boot time. The Siglent uses about a minute to boot, while the RTB2004 uses about 15 seconds. Not a big deal since you can leave the scope powered on due to the fan noise being barely noticeable.
« Last Edit: December 05, 2023, 11:08:23 am by hansibull »
The following users thanked this post: Performa01, 2N3055, KungFuJosh, Martin72
Offline fhw72
 ;D X-Mas time: I'm contemplating to upgrade to HD (I already have a SDS2000X+ - which has the 100% discounted upgrades).
Maybe you can give a hint?  :-DD
« Last Edit: December 21, 2023, 06:43:55 pm by fhw72 »
Online Grandchuck
Siglent SDS2000X Plus - Bugs / Missing Features / Feature Requests New
« 1 2 3 4 5 6 ... 36 »
36 pages!  How many bugs and missing features have been addressed in the HD model?
Offline Martin72
36 pages!
This means what ? Every post a bug ?  ;)
Online ebastler
36 pages!
Every complaint post triggering four further posts from the Siglent crew which explain why it has to be that way? ;)
Online KungFuJosh
  • TEAS is real.
36 pages!
Of course! We always stay on topic and keep opinions and rivalry out of every thread. 🤣🤣🤣
Online Grandchuck
So I can assume none/nothing have/has been addressed?
Online KungFuJosh
  • TEAS is real.
You can assume whatever makes you happy. Or read some of the threads if you want. Or look at revision histories of the firmware that mention a lot (but not all) of the improvements. The world is your oyster!
