@JJ_023
The GPP-4323 is a decent supply but it does have its drawbacks. For these reasons I recently sold mine after about a year and got a different unit.
The things I am referring to might seem petty, but I found them very annoying. The things I don't like about the GPP-4323 are:
1. The screen is really too small for display all 4 channels at once. If you have it directly in front of you, its okay. But I have my power supply on the shelf above my bench, and I find it very difficult to read all of the settings for all of the channels because the font is so small. I actually sent an email to GW-Instek requesting a FW update that made the font a bit larger and possibly removed other things in the window such as OVP and OCP....and they basically were not interested.
2. The layout of the binding posts on the front panel is very ackward for me to get used to. From a very early age I learned to read from left to right and that you count 1,2,3,4 in that order. Instek decided on this goofy arrangement of Channel 4-1-2-3 on the front panel makes sense. I could never get used to this and it was always confusing.
3. Related to #2 above, the screen which shows each channel's status is shown as channel 1 and 2 on the top, and channels 4 and 3 on the bottom (in that order). Again, I find this very annoying because I'm accustomed to counting 1-2-3-4 (reading from left to right).
4. The binding posts are not really color coded and marked very well. Most mfgrs put a red ring around the positive and black ring on the negative binding post at the end of the binding post. Instek only has the small red and black band BEHIND the binding posts, and I found myself spending way too much time just to make sure I have the right polarity and connected to the right set of binding posts.
As others have mentioned, this unit has good specs and built well, but these user interface issues mentioned above became a real problem for me. If you don't think these issues would bother you, this unit is pretty good.
In case you are wondering, I purchased a Rigol DP932E as a replacement for the Instek unit, and added the $100 high-res option (although I think that is hackable now). Although it's only 3 channel, I find that the user interface is much more friendly than the Instek and it's much easier/quicker to connect my leads and read the current/voltage of all the channels.
Just my opinion for what its worth. Good luck in your decision.
