Author Topic: Is there a better power supply option for $700?  (Read 6098 times)
Offline JJ_023Topic starter
« on: January 03, 2024, 04:17:31 pm »
I am doing some research into purchasing a power supply.  I've narrowed it down to Instek GPP-4323 (LAN)
I need a power supply for basic general needs and for learning basic electronics stuff.  Some of the uses would be for.
Working with microcontrollers Arduino etc.
Working on current sensing and voltage sensing circuits.
Working with and designing operational amplifier circuits.
Charging all sorts of batteries.
Working with smaller servomotors.
General electronic needs.
Repair work with voltage injection etc.
My reasons for selecting this particular power supply.
I like GW Instek.
Seems to have decent specifications.
Low ripple.
Decent response time.
Is able to function as a load (as far as I understand although it is limited in capacity)
Seems to have a pretty decent user interface and layout with extra buttons for convenience.
I am looking for the community's help in making this decision.   Also would love to hear from anybody that has actually used this particular power supply and there experiences.
I am looking primarily for something new not used off of eBay.
This power supply is probably way overkill for the needs that I have but I believe in buy once cry once approach to purchases.
If there is something in this particular price range that is better I would love to hear about that as well.
I would like to thank everyone in advance that contributes to this post.
Thank you.
Online mawyatt
Re: Is there a better power supply option for $700?
« Reply #1 on: January 03, 2024, 04:32:32 pm »
Getting a good quality PS for development work is a good decision, many folks don't and suffer the consequences!!
The GPP-4323 is an excellent choice, we have one and use it. Having 4 controllable outputs is a plus in many uses, and the EL is also a nice somewhat unique feature is this price range. This supply is accurate, stable, WO overshoot on Startup and Stop/Unplug, so good to use with sensitive low voltage circuits.
We also have the SPD3303X (have 3), however these don't have 4 outputs, and only 2 are fully controllable. This is a good supply for the $, but lacks the features of the higher $ GPP-4323. Siglent has introduced a new PS series, but no reviews yet, and availability uncertain.
Best,
~Wyatt Labs by Mike~
The following users thanked this post: JJ_023
Offline PlainName
  • Country: va
« Reply #2 on: January 03, 2024, 05:04:55 pm »
« Reply #3 on: January 03, 2024, 05:52:31 pm »
Best,
Thank you for such a detailed response.  I had a few follow-up questions.  The load feature,  what is the maximum that it can be used for?  Would it handle something like 12 V at 3 A?
What is something that you dislike about this power supply?
« Reply #4 on: January 03, 2024, 05:53:36 pm »
If I had that money to spend on a PSU, I'd have no problem purchasing another EEZ BB3:
https://www.eevblog.com/forum/projects/eez-h25005-a-possible-successor-of-eez-h24005-programmable-power-supply/msg1621891/#msg1621891
Thank you for the recommendation.  I tried researching the price on Google.  It seems like a very convoluted buying experience.  Also it's made in Croatia so how is warranty work going to work?
I'm sure it's a wonderful unit with better specs but just not for me.
Offline Randy222
« Reply #5 on: January 03, 2024, 06:55:04 pm »
I not a big fan of buying more than what you actually need. Spending +$200 on extra features you will likley never use, is $200 you could use elsewhere (tools, meters, whatever).
So is the question really just "Can I get better than a GPP-4323 in my budget of $700?" ?
Define the needs, go from there. The Mastech tri-output box (old) on my desk has let me do lots of small projects from a PSU view, non-precise PSU at that. 2 buttons and 4 dials, that's all it has.
Some of the items listed (op amps, etc) might be in ckt's that require a precision voltage reference, but you get that from an IC, less so from a PSU.
I always think of PSU's as the coarse dial into any ckt that uses power, and then the ckt itself has the IC's needed to create precision.
« Reply #6 on: January 03, 2024, 07:20:41 pm »
Thank you for your response and thoughts.  To answer your question directly, YES, Can I get better than a GPP-4323 in my budget of $700?
I agree that I could do with less.   I agree with some of your other statements.
The one place where I disagree is in our tool philosophies.  I have acquired a lot of tools over the years.  One thing that I learned is that you can make do with something less and invest into other things that might be useful that will help you along in terms of whatever. However in the long run as your finances and/or your skill set and knowledge expand you always have a need for the better tool.  The cost of selling a cheap tool and then buying a more expensive tool oftentimes ends up costing more in the long run.
I have used every single 1 of my tools to make money with it at one point or another, so I prefer just to buy something decent from the get-go.
I seen so many people start with either a cheap welder, cheap meter, cheap C&C whatever it is and then regret it down the road.
Now if you have a limited budget and you are just starting out I think your advice is very sound and makes a lot of sense not only in terms of electronics but business in general.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #7 on: January 03, 2024, 07:20:54 pm »
The GPP-4323 is very decent. The load function can be very useful. And it's very responsive on the communication ports.
It measures very accurately! And the unit also offers paralleling/serialling without external wiring, which can be useful.
GW instek makes decent quality. I would recommend this supply!
The only drawback is that ethernet is not standard, and you can't read the channel numbers when you're looking from high because of the indent. (they are not 1-2-3-4)
« Reply #8 on: January 03, 2024, 07:35:36 pm »
Thank you for your response.  Could you clarify this statement.  I am not getting the gist of it.
Offline ArcticGeek
« Reply #9 on: January 03, 2024, 08:35:55 pm »
@JJ_023
The GPP-4323 is a decent supply but it does have its drawbacks.  For these reasons I recently sold mine after about a year and got a different unit.
The things I am referring to might seem petty, but I found them very annoying.  The things I don't like about the GPP-4323 are:
1.  The screen is really too small for display all 4 channels at once.  If you have it directly in front of you, its okay.  But I have my power supply on the shelf above my bench, and I find it very difficult to read all of the settings for all of the channels because the font is so small.  I actually sent an email to GW-Instek requesting a FW update that made the font a bit larger and possibly removed other things in the window such as OVP and OCP....and they basically were not interested.
2.  The layout of the binding posts on the front panel is very ackward for me to get used to.  From a very early age I learned to read from left to right and that you count 1,2,3,4 in that order.  Instek decided on this goofy arrangement of Channel 4-1-2-3 on the front panel makes sense.  I could never get used to this and it was always confusing.
3.  Related to #2 above, the screen which shows each channel's status is shown as channel 1 and 2 on the top, and channels 4 and 3 on the bottom (in that order).  Again, I find this very annoying because I'm accustomed to counting 1-2-3-4 (reading from left to right).
4.  The binding posts are not really color coded and marked very well.  Most mfgrs put a red ring around the positive and black ring on the negative binding post at the end of the binding post.  Instek only has the small red and black band BEHIND the binding posts, and I found myself spending way too much time just to make sure I have the right polarity and connected to the right set of binding posts.
As others have mentioned, this unit has good specs and built well, but these user interface issues mentioned above became a real problem for me.  If you don't think these issues would bother you, this unit is pretty good.
In case you are wondering, I purchased a Rigol DP932E as a replacement for the Instek unit, and added the $100 high-res option (although I think that is hackable now).  Although it's only 3 channel, I find that the user interface is much more friendly than the Instek and it's much easier/quicker to connect my leads and read the current/voltage of all the channels.
Just my opinion for what its worth.  Good luck in your decision.
« Last Edit: January 03, 2024, 08:39:20 pm by ArcticGeek »
The following users thanked this post: thm_w, JJ_023
Offline jjoonathan
« Reply #10 on: January 03, 2024, 09:02:10 pm »
I went a different path and fixed the channel coloring on the GPP-4323 with markers. Two years later, I still love this little supply!
The following users thanked this post: mawyatt, JJ_023
Offline flano
« Reply #11 on: January 03, 2024, 09:23:51 pm »
I purchased a GPP-4323 and it worked ok for a couple of days and then stopped booting. I received a replacement unit from Element 14 and straight out of the box did the same thing. Both units were sent back to Element 14 and then to GW Instek and were unable to be repaired. I wasn't provided any further info on the fault.
Apart from the fault, I liked the GPP-4323, four outputs and good accuracy, but wasn't willing to try my luck with a third unit.
I ended up buying a DP932E and I'm very happy with it. Touch screen is nice.
Hope this helps you in your decision.
Mike. VK4MWL.
Offline points2
« Reply #12 on: January 03, 2024, 09:40:38 pm »
hi JJ_023,
this one ? => https://eleshop.eu/gw-instek-gpp-4323-programmable-power-supply.html
nice gear...
Honestly, I don't have any benchtop PS, because I'm dealing with voltages below 5VDC at PCB level.
So,
- for "learning basic electronics stuff" => I can't see the point to use any benchtop PS given their noise. I prefer my current setup : various SMPS (dead cheap), to deliver 3.3 / 5 / 9VDC => followed by a linear module (based on LT3045), with adj. Vout. With that, I get dead clean Vout thanks to the linear module (Vajd, thus, I can get what I need...). ICs need that kind of PS : no ripple, and able to match their transients.
- for "basic general needs" => having a couple of Meanwell (@ 25eur each), that deliver high A & 1 or 2 output voltage => far enough, & cheap vs any benchtop PS
A "all-in-one" PS for gen.purpose (=apple) AND investigations at PCB level (=caviar  :palm:) => it doesn't exist
If you need to "learn" about electronics (that what you says ; given that I'm a noob although I'm climbing the learning curve... a never ending story that hobby  :-DD ),
please explain what instrument you have... there is maybe a better investment to do prior to a costly PS (VNA / SA / soldiering station / microscope / ... many ways to spend money & learn about EE).
My 2 cents.
PS : just my view vs PS, I'm a nice guy, don't bite please !  :)
Offline Antonio90
« Reply #13 on: January 03, 2024, 10:03:44 pm »
I have a GW Instek, a GPD-4303S. It works quite well as a psu, reasonably precise, stable, and reliable OCP and OVP, but cannot show the settings of more than two channels at once on the screen, and you have to turn on/of all channels at once. This last flaw is, by far, the worst.
If I were to buy another PSU right now, it would probably be the one you are considering. There is custom firmware in this forum for the GPP, which improves readback speed, and accuracy? Can't recall right now.
I would have a look at AIM-TTI supplies. They are also really precise, with sense terminals on the front, and simple interfaces. More expensive for the same features, and I don't think you will get two quadrant supplies for that budget outside of the GPP. The MX series from TTI look quite nice though.
« Last Edit: January 03, 2024, 10:06:39 pm by Antonio90 »
« Reply #14 on: January 03, 2024, 10:05:11 pm »
@JJ_023
Thank you for such an elaborate response.  When it comes to personal preferences I don't think anything is petty.
1.  I can't really comment on the screen size because I haven't seen this particular unit in person.  Usually that sort of stuff won't bother me as much.  I think you can run it off the PC.  Is this not the case?
I'm also surprised that some of the talented people on this forum that have this particular supply have not figured out a way to adjust the font size.
2.  I agree that is a pretty stupid way of doing it.
3.  This is also pretty stupid, I totally agree.  Do they issue firmware updates? If so how often?
4.  This also doesn't make much sense however I would probably solve that with a sharpie.  Don't laugh.
I have thought about the Rigol seems like a decent unit.    Is there anything about the Rigol that you don't like and bothers you as well?  Why is the DP932E 195W and the DP932A 210W.  I thought it is basically the same unit that's why it is upgradable.
« Reply #15 on: January 03, 2024, 10:10:39 pm »
Thank you for that.  It's not a bad idea but I am fairly familiar with industrial paint and paint composites.  Markal sells a paint marker specifically for oily metal that basically writes on anything and is very tenacious.  Sometimes it's difficult to get off even with acetone.  The downside is it takes a little bit of time for it to dry which makes it very prone to smearing.  Long time being roughly 5 minutes.
The following users thanked this post: jjoonathan
« Reply #16 on: January 03, 2024, 10:12:04 pm »
Mike. VK4MWL.
Thank you for the data point.  What is something that you don't like about the Rigol?  I've considered that unit as well.
« Reply #17 on: January 03, 2024, 10:20:12 pm »
hi JJ_023,
nice gear...
So,
My 2 cents.
You are a nice guy so thanks for the contribution.  That is the exact supply I am referring to in your link.
I understand what you are trying to do with guiding me to possibly a better purchase decision for an overall EE set up.   I am pretty set on my next purchase being a power supply and I would like a fairly decent one.
Besides EE just being able to charge batteries, utilize a temporary replacement for a broken wall wart I can't find, to testing small servos to troubleshooting, repair with voltage injection and current limiting.
« Reply #18 on: January 03, 2024, 10:28:34 pm »
Thank you for taking the time to respond.  Not being able to show more than 2 channels at the same time might be a nuisance in certain occasions I don't particularly see that as that big of a nuisance.  Can you control this on a PC screen?
If I understand you correctly that is a big PITA.  I see 4 buttons for channels.  What are they for if you can't turn them on and off independently?
I don't necessarily need the 4 channels but it is an appealing feature.  I am not familiar with that particular brand I will have to do a little bit of research.  Do you have a specific model you would recommend without getting into a different price bracket?
Offline Veteran68
« Reply #19 on: January 03, 2024, 10:45:01 pm »
I'd have to disagree. After maybe a good DMM (or two, preferably) and a soldering iron, maybe an oscilloscope depending on what you do, I'd consider a bench PSU to be the next must-have for any aspiring hobbyist. It's one of my most used and useful tools. I use it way more than my scopes. In fact I often use more than one at a time. My Siglent 3303X has 3 channels but can only output 3.2A on a single channel. I can parallel two channels to get 6A, but then that takes both variable channels and leaves me with a 3rd channel that can only do 2.5v/3v/5v.
Why do I sometimes need more than 3A? Or even 6A? I work on laptops and sometimes need to power the laptop from a bench supply. Most modern laptops take 20V3A at a minimum for a simple business laptop, and up to 10-12A for workstation or gaming laptops (180-240W). So I have a 30V10A supply wired up with a universal power plug set that I can use to power a laptop or pretty much any consumer device up to 30V10A.
I also have a Tekpower 30V5A linear PSU that I don't really use on the bench anymore but will grab and take with me if I need a PSU somewhere else.
Maybe if all you do is simple microcontroller breadboard designs that could basically get away with a very low voltage/amp supply or even a battery pack or two, then I could concede the point. But if you do any sort of repair or troubleshooting of consumer electronics, you're going to need more than an ultra-low power supply pretty quickly.
The following users thanked this post: nctnico, JJ_023
Offline zepto
« Reply #20 on: January 03, 2024, 11:53:17 pm »
I know that this statement was written in bold, but I would urge you to reconsider. High quality used power supplies are fairly abundant in the USA.
Former klystron tuner
Offline points2
« Reply #21 on: January 04, 2024, 12:03:53 am »
hi JJ_023,
sorry about my previous post...  :-+
"Electronic" is a like a so large field of grass, that people who deal with issue "x", can't see people who deal with issue "y" over the horizon... cause this field is so so large
I'm pretty sure that, b4 posting, you've "plowed" (direct translation of french slang, not sure it is the right equivalent in english, but you see what I mean  :) ) the web to find the product that fits your needs (x ouputs / A @ output / V range etc....), reviews here & there to get info vs reliability (given the price & given it is a heavy duty device, reliability over 3yr min is a minimum.
The product you find has a load function => cool !
I see what you mean, no brainer, fine !  :-+
Offline jjoonathan
« Reply #22 on: January 04, 2024, 12:04:32 am »
Nice! I'll file that away, it sounds useful.
Online 2N3055
  • Country: hr
« Reply #23 on: January 04, 2024, 12:13:21 am »
One thing is that you do need proper lab psu.  More than one, isolated from each other.
Other thing is what kind.
You won't need network connected smart PSU most of the time.
Most of the time simple analog one with potentiometers is good enough.
You can have several single channel ones instead of one multi channel.
You want a smart one with LAN and SCPI only if you want to write scripts to automate it.
Also some multi channel PSU have weird channel combinations. Instek GPP-4323 has 2 channels with full capacity but 15V and 5 V have only 1 A capacity. Some will argue that it would be more useful to have 3 full capability channels instead..
It all depends on your needs.
Dr. Richard W. Hamming
Offline points2
« Reply #24 on: January 04, 2024, 12:33:35 am »
hi Veteran68,
I'd have to disagree....
as I said on my previous post, "electronic" is a very wide field...
but you said is more "electricity" stuff than "electronics"
to me, "electronics" relates to "PCB level", thus V=<3.3VDC roughly...
I'm a young player in EE, but from start I found strange that people dealing with EE deal with V>5VDC (OCXO with Vin=12VDC are over the place, but are old-stuff).
stuff.
- breadboard => noise => no go
- battery as PS : => noise & sluggish vs transients => no go
- consumer electronics => 5/9/12V input (box), but then, inside the box > you got the input V down-step to match the PCB level => 3.3V or less... and so so..
Sorry about all my blabla
I just pointed out that "PCB level" is fun because it's  |O and then you overcome the issue => go to the next  |O ... I love that....  :-DD
To anyone, enjoy '24 ! lot of fun etc !  :-+
