Author Topic: Is there an inexpensive DMM with FAST MIN/MAX (NOT just MAX) function?  (Read 7161 times)
Offline Adam BaumTopic starter
Question in thread title.
Online bdunham7
Re: Is there an inexpensive DMM with FAST MIN/MAX (NOT just MAX) function?
« Reply #1 on: February 05, 2024, 04:34:57 pm »
Sure.  How fast and how inexpensive?  You'd need to quantify those attributes to get a meaningful answer.
The following users thanked this post: thm_w, Fungus, mwb1100
Offline myf
« Reply #2 on: February 05, 2024, 04:38:35 pm »
Hello,
The (old) ut-61e has min and max values.
The value read is a very fast transient, not the average over a period (0.5s).  I read about 20A or 30A when charging a 4700 µF capacitor with a laptop-type power supply (36V - 4A).
Offline Fungus
« Reply #3 on: February 05, 2024, 04:42:54 pm »
What bdunham said, and:
What sort of signal are you looking at? What time frame?
You can get pocket oscilloscopes for about $30. They have very fast min/max over short periods of time.  :)
Offline RtBNL
  • PH1X
    • De audiowerkplaats. (Dutch only)
« Reply #4 on: February 05, 2024, 04:58:45 pm »
Both the Brymen 869 en 789 have a very fast min/max (crest function) they both measure the peaks op(~+ & - 325v] on the wall outlets that give ~230 volts.
« Reply #5 on: February 06, 2024, 11:46:42 pm »
Hello,
I own a Fluke 77 and a Fluke 17B and, of course, the 17B+ has min/max and not the 17B.  Rather than spending $188 for a 17B+ just to get that function, I'd like to spend as little as possible.
Your UT61E lead got me there, so thanks. It looks like the UT61B+ (with min/max) or UT61D+ (with min/max and peak min/max) are the ones to go with.  The 250us capture time is the same as with the much more expensive Flukes with min/max.
« Last Edit: February 06, 2024, 11:55:10 pm by Adam Baum »
Offline mwb1100
« Reply #6 on: February 07, 2024, 05:28:29 am »
Where did you find this spec?  I can't find it in the Uni-T UT61+ data sheet or user manual.
Online jfiresto
« Reply #7 on: February 07, 2024, 09:05:48 am »
If the meter uses a DMM chip, have you checked its datasheet?
The datasheet for the Cyrustek ES51962 in my B&K 390A quotes a worst case error for a 10µs pulse of +/-2% + 25 counts.
-John
« Reply #8 on: February 08, 2024, 06:08:31 pm »
Somewhere in this section on their slow as snot web page :
https://meters.uni-trend.com/services-support/faqs/
"For peak measurement: Maintain the MAX/MIN value of pulse signal automatically, the response time of logging MAX/MIN peak value is short (about 250us), a transient value can be measured accurately through this function."
The Fluke figure came from here:
https://www.fluke-direct.com/pdfs/resources/fluke/How-to-use-Fast-Peak-Min-Max-on-your-DMM-usd.pdf
The FAST MN/MX (187, 189) or Peak Min/Max (87V) function is restricted to the voltage and current measurement. FAST MN/MX or Peak Min/Max can be used to capture intermittent or transient events that occur on a monitored signal over time. Events as short as 250 μs (or longer) can be captured...
« Last Edit: February 08, 2024, 06:11:16 pm by Adam Baum »
The following users thanked this post: mwb1100
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #9 on: February 08, 2024, 06:40:06 pm »
In my tests with peak mode at a low level (5V), the UT61E (non plus) was the champ (1us) when compared to all others.
I did a video comparing several meters (in portuguese, sorry), Skip to 13:58 for the UT61E.
