Author Topic: Is there such a thing as a Lab Power Supply with a decent UI?  (Read 16980 times)
Offline Marco
Re: Is there such a thing as a Lab Power Supply with a decent UI?
« Reply #50 on: March 19, 2017, 12:28:25 am »
Only the sensor is inexpensive.  Include the rest of it and the development part is $150.
If your time is free, just experiment ... and report the results :p AFAICS the datasheet is complete. Diametric magnets, steel rod, bushings, springs ... it's all cheap.
Offline AlanS
« Reply #51 on: March 15, 2019, 01:37:00 am »
For me it's the Keysight E36313A - John Kenny gives a good overview on YouTube.
The second best is the Prasimix's H24005A - a wonderful beast. Its screen is a little small and fiddly with fat fingers and it would benefit from having separate voltage and current knobs - with switches at each output. But still the best affordable P/S I've seen.
Online MarkF
« Reply #52 on: March 15, 2019, 02:36:17 am »
Poor yellow on the display for channel 1.
If they want to use yellow, then make the display yellow and NOT olive green.  :--
Offline David Hess
  • DavidH
« Reply #53 on: March 15, 2019, 03:02:02 am »
I wonder if they care about the lesson Xcelite learned.  Inexplicably, a higher percentage than expected of male technicians and engineers are color blind.
Offline CrazyTiger
  • Country: my
« Reply #54 on: March 15, 2019, 02:29:00 pm »
I did happen to see the new R&S Power Supply NGL200, the UI is looking good :-+
The price point is about 2K euro for the base model  :palm:
The best part is it has 6.5 digit resolution
https://www.rohde-schwarz.com/nl/product/ngl200-productstartpage_63493-596117.html
*email tag removed
« Last Edit: March 15, 2019, 10:57:56 pm by CrazyTiger »
Offline nctnico
« Reply #55 on: March 15, 2019, 10:12:41 pm »
The best part is it has 6.5 digit resolution :-+
You need to have deep pockets for this one:
Copy & paste from the website: Starting at EUR30,382,000  :scared:
Offline Caio Negri
  • Country: br
« Reply #56 on: March 16, 2019, 08:27:40 pm »
*email tag removed
I find it weird that the 2-ch model doesn't have sense terminals on the front.
"Start where you are, use what you have, do what you can." - Arthur Ashe
Offline AlanS
« Reply #57 on: March 17, 2019, 07:54:39 am »
Hmmm. Didn't notice that on the video - but the real thing is a lot better.
Offline colorado.rob
« Reply #58 on: March 17, 2019, 05:17:37 pm »
The price is not horrible considering it is a two-quadrant device, able to sink current.  It is a shame that Ethernet is a $$$ option and not standard.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #59 on: March 17, 2019, 06:45:23 pm »
I was going to say that as well - the yellow is much better than what is shown in the video. Perhaps there was a white balance mishap during shooting.
The fact the Keysight can "zoom in" a channel of interest is quite interesting for me. However, I find the fonts of the options at the bottom menu a bit too thick for my taste, but this is nitpicking.
« Last Edit: March 17, 2019, 07:50:00 pm by rsjsouza »
Offline james_s
« Reply #60 on: March 17, 2019, 07:42:03 pm »
I cannot imagine what I would need or want ethernet for on a power supply, certainly I wouldn't pay extra for it. IMHO nothing beats old fashioned analog knobs.
Offline rsjsouza
  • Eternally curious
« Reply #61 on: March 17, 2019, 07:52:59 pm »
I would love if the E36312A had a better acceleration on its encoder knob - that or a fixed faster setting. I miss being able to continuously change a voltage using the knob.
Offline David Hess
  • DavidH
« Reply #62 on: March 17, 2019, 08:12:34 pm »
I would want Ethernet on a source-meter in place of GPIB or serial for automation.
Offline james_s
« Reply #63 on: March 17, 2019, 09:36:55 pm »
If one is doing automation then some form of connectivity is great, but most people using a bench power supply are likely using it on a bench. Certainly I'm not doing production testing on my hobby bench, when I want to change the voltage I want to reach for a knob and change it. The best arrangement I've used has separate knobs for coarse and fine adjustment.
« Reply #64 on: March 17, 2019, 10:35:33 pm »
Yeah sure but if you need to check power ON rail sequencing then you need a programmable output timer function that you can set with the physical UI or via some utility program.
When you have projects/products with multiple rails you have to have the tools to allow this ^ or suffer any manner of unexplained behaviors.
Avid Rabid Hobbyist
Offline nctnico
« Reply #65 on: March 17, 2019, 10:56:23 pm »
I hate fine and coarse adjustments. The fine adjustment is always at the end so you keep going back & forth. So far my favorite way of setting a voltage is just keying it in through a numerical keypad.
