Author Topic: is this a fluke? (117 ghost? current)  (Read 2969 times)
Offline AnthocyaninaTopic starter
  • The Sara
« on: November 25, 2022, 09:17:32 am »
I recently got a fluke 117 and I haven't used it much, and when i have, it has only been for circuits using 5v and for continuity, and the day it arrived, i also shorted some AA batteries with it to see the current go up, everything seemed fine afterwards and it was left turned off for a while. today i needed to measure some currents in the order of a few milliamps, and grab it for that, but when turning it on, i encountered this strange thing, it shows 4 mA DC with nothing plugged into any terminal, and when switching to AC current, while it displays 0.000, the first segment of the bargraph flickers on and off.
I opened it and took out the fuse, and it still behaved the same way. Then i changed the battery, and it showed 0.000 A on DC but the bargraph still flicked on AC, and after a few minutes, the 4mA started to show up again when on A DC.
Any idea what might be going on?
Thank you!
Offline evava
  • Country: cz
Re: is this a fluke? (117 ghost? current)
« Reply #1 on: November 25, 2022, 09:57:56 am »
I think you should plug in the test leads, then look at display in DC mA range ?
(split input terminals)
  • The Sara
« Reply #2 on: November 25, 2022, 10:12:04 am »
Thanks, I've already tried shorting the terminals with the leads. This meter doesn't have a mA range unfortunately
Offline skander36
« Reply #3 on: November 25, 2022, 10:28:41 am »
Maybe need calibration? (ofsetting)
My fluke 87V also show 2 mA on iddle and I have others that fluctuates on iddle (plus or minus 1-2 mA).
The following users thanked this post: Anthocyanina
  • The Sara
« Reply #4 on: November 25, 2022, 10:52:34 am »
Thank you, i tested various currents (through a 100 ohm resistor), and it does seem to be a constant offset! I do wonder what caused this offset to appear while it was just sitting there unused for a few days, hmm!
« Last Edit: November 25, 2022, 10:56:25 am by Anthocyanina »
Offline Caliaxy
« Reply #5 on: November 25, 2022, 06:37:23 pm »
This meter is not intended to measure mA. Keep in mind that you are on the 6A range, trying to measure 10-60 mA (<1% of the full scale). Not to mention the 1% + 3 digits accuracy... It's normal, your Fluke 117 works as it should. Use your Aneng to measure mA.
Offline BeBuLamar
« Reply #6 on: November 25, 2022, 07:07:07 pm »
I think you blew the fuse when you shorted the battery. You need to check and see if the fuse is still good.
Online Martin72
  • Testfield Technician
« Reply #7 on: November 25, 2022, 10:31:18 pm »
Exactly this, we got several of them here, but we don“t use them for mA measures.
