I've purchased the Aneng AN8008, but I'm having issues with the mV range. It is a minor nuisance, but the multimeter seems to drift towards the negative end, until it displays "OL" after about one minute with the dial on that setting. Is this normal? I don't wist to buy another unit, but I think I got a defective one.
Funny enough, I can't always measure this "OL" voltage with another multimeter, since it will mostly dissipate as soon as I try. Sometimes I see it sitting at 0.3mV, on both multimeters, sometimes I measure it at 1.6mV, and rarely I see a fluctuating voltage of about 120-130mV. This behavior changes by disconnecting and reconnecting the probes. What is consistent is the fact that goes to "OL" or stays like that with the probes fluctuating.
This only happens if the problematic multimeter is set in the mV range. The V range works as intended, and doesn't output any voltage that I can measure. I tried to measure the current that the Aneng is outputting in the mV setting, but to no avail. The other multimeter doesn't register anything in the uA range.
Kind regards, Samuel Lourenço
