The entire banana jack assembly ripped out of the meter through the front plastic without breaking the tabs in between?
No, as I've specified under the image, this is an already desoldered assembly, the issue is with the guts of the first (and most used) connector falling right the heck out when pulling the probe out
Therefore, there is nothing holding the contact plates together now, which is a recipe for intermittent contact, with the probe wiggling around in the socket...
The thing is, it actually broke off, like, during the first week of usage, I tried to glue it back together several times, which worked for a while...but enough is enough, the part needs to be replaced altogether.
