I'm still a newbie at electronics, and I could use some clarification on how to not overload this device.
From the PDF for the uCurrent, it saids not to put more current than the range for that current selection, or else you might blow the shunt resistor. This is the top end for each range selection.
300mA [mA range]
1mA [uA range]
1uA [nA range]
Let's say I have a microcontroller that sleeps for 10 seconds, wakes up and lights up LED, and then sleeps for another 10 seconds. I want to measure sleep current. I would keep the selector switch in [uA range] to measure the sleep current consumption. But when the microcontroller wakes up, the wake up activity consumes more current than the 1mA allowed in the [uA range]. Would that blow the shunt resistor? Would I have to move the selector switch from [uA] to [mA] quickly before the microcontroller wakes up? It seems like a pretty risky operation. Wondering if my understanding of overload current is correct, and if there's a better way of making this measurement?
Also, if you opt to use 3xAAA, would you solder wires from the AAA battery holder directly to the coin cell contacts? Or is there a better way I'm not seeing?
Thank you.
Jason
