Author Topic: It is safe to use the TG output of the SA without a 50R load?  (Read 1621 times)
Offline mcinqueTopic starter
  • I know that I know nothing
I'm not an expert of SA other than EMC testing use. So I thought it's better to ask.
I need to find the resonant frequency of a metal shielded box which is not perfectly square (it has many elements inside that modify the inner geometry). Since that I cannot simply do math to find that frequency.
It is safe to use the TG connected by a bnc<|>bnc to a small wire as antenna inside the box near another bnc<|>bnc conneced to the SA input?
The idea is to sweep the frequency with the TG to see the resonant one, like this
Would the TG output require a 50R load? And can it be damaged from reflections/SWR?
« Last Edit: March 15, 2017, 11:08:00 pm by mcinque »
Offline TheSteve
  • Living the Dream
Re: It is safe to use the TG output of the SA without a 50R load?
« Reply #1 on: March 15, 2017, 11:53:05 pm »
There should be no damage with no 50 ohm load - it never hurts to consult the manual for whichever model you happen to have though.
VE7FM
The following users thanked this post: mcinque
Offline David Hess
  • DavidH
« Reply #2 on: March 16, 2017, 03:03:09 am »
The tracking generator output is not going to be damaged by operation into a short, open, or any length of cable with or without a passive load on the end.  The power levels are too small.
If you are concerned, then put a 50 ohm attenuating pad (3dB, 6dB, 10dB, whatever) between the tracking generator output and the load which will attenuate any reflected signal.
« Reply #3 on: March 16, 2017, 12:29:00 pm »
Thank you for your reply.
Yes, indeed. Unfortunately in the manual there is no advice or warning (at least I didn't find it!) about TG output without a load, so I asked here :)
Good advice, thank you!
