Products => Test Equipment => Topic started by: mdronic on May 27, 2015, 05:05:50 am
Title: itt metrix mx202b multimeter manual info
Post by: mdronic on May 27, 2015, 05:05:50 am
I purchased an old itt metric mx 202b multimeter. I've been trying to find a manual and schematic for it. I've found the schematics however all the manuals I can find are  in French. As my French is very poor does anyone have one in English. From what I can get the gist of the battery replacement can be an issue and they are circa 1967?. Does anyone know anything about them. It's working and I just liked the look of it and thinking nice to use analogue sometimes. Thanks.
Title: Re: itt metrix mx202b multimeter manual info
Post by: OldNeurons on May 27, 2015, 08:26:48 am
Will try to help you ...
I visited various french websites about this mx202b. This model was using a mercury battery model RM.1R, voltage: 1.35v.
There are several solutions for the replacement. The easiest one is may be this:
http://www.smallbattery.company.org.uk/sbc_mr50_adapter.htm (http://www.smallbattery.company.org.uk/sbc_mr50_adapter.htm)
You could also adapt a 1.5v battery together with such regulator:
http://fr.farnell.com/texas-instruments/tps709135dbvt/regul-v-2-7-30v-0-245vdo-1-35v/dp/2314369?Ntt=2314369 (http://fr.farnell.com/texas-instruments/tps709135dbvt/regul-v-2-7-30v-0-245vdo-1-35v/dp/2314369?Ntt=2314369)
http://www.farnell.com/datasheets/1882939.pdf (http://www.farnell.com/datasheets/1882939.pdf)
Hope this helps ...
Good luck !
Post by: mdronic on May 31, 2015, 05:33:50 am
Thank you for your help. Out of curiosity does anyone else use one ? . Really like the side adjustment over the rotary dial type analogue multimeter s.
Post by: OldNeurons on May 31, 2015, 09:33:12 am
If you decide to go for solution 2 (adapt new batteries with a TPS709135 regulator), here is a link to clear instructions how to do the modifications.
It is in french, but with the help of Google translate and the pictures you should be able to do it.
http://radioman64.e-monsite.com/medias/files/remplacement-de-la-pile-dans-un-metrix-mx202.pdf (http://radioman64.e-monsite.com/medias/files/remplacement-de-la-pile-dans-un-metrix-mx202.pdf)
If you need a partial translation of the document, just tell me.
Post by: reinhardz on August 05, 2015, 09:34:56 pm
I could send you a scan of the manual in English language. Still interested?
CU
reinhardz
Post by: jukees on May 25, 2016, 06:19:10 am
CU
reinhardz
I have a that meter, and i would like to read the manual. If you're still willing to scan it, i would like a copy.
Post by: reinhardz on May 27, 2016, 03:06:29 pm
You can find it now here:  http://elektrotanya.com/Metrix_MX202B_User_Manual_en.pdf/download.html (http://elektrotanya.com/Metrix_MX202B_User_Manual_en.pdf/download.html)
For download please click on the arrow in the violet circle on the left.
BTW: At Elektrotanya, a German user manual can be found now, too.
Best regards
reinhardz
Post by: rf-loop on May 27, 2016, 03:26:04 pm
Of course nearly everyday use. Analog meter is really superior in some works and this meter is one of best.
Over all digital scopes and meters I still use analog scope(s) and analog multimeters (In some specific cases relating to maintenance and repair work). Reason is so simple. Money.
